What's my vacuum gauge telling me? - Page 2 - Fuelly Forums
Old 05-09-2006, 09:36 AM   #11
i shift pretty much at the
i shift pretty much at the same points you do.
Old 05-09-2006, 11:05 AM   #12
95metro's Avatar
That's good to know. The
The vacuum gauge is pretty much doing what the ScanGauge's instant mpg reporting from what I can understand. Which seems to be tied into the instantaneous throttle response. As rpm increases, vacuum increases as long as the throttle remains in the same position.
If there were some way to capture and graph the instantaneous readings then I would be able to match the gauge readings to roughly extrapolate my instant mpg. Over time I may be able to start guess-timating and adjust my driving to suit.
95metro is offline   Reply With Quote
Old 05-09-2006, 05:48 PM   #13
FE
RPM is a demonstrated FE killer under steady load
Yeah But I mean for acceleration - quick revs in the 2 lowest gears and pop it into 5th at 25mph instead of a little 1st 2nd 3rd 4th then 5th. Got to get the oil flowing a little.
Old 05-09-2006, 05:52 PM   #14
vacuum
Keep the Vacuum at a constant mid range and you maintain a constant vacuum advance on the timing which helps burn the fuel a little better, gets more power and constant vaporization of the fuel.
Old 05-09-2006, 05:59 PM   #15
Re: FE
ah, gotcha. have you tested it with your scangauge on the xb? what does it like in terms of acceleration?
i wish someone would do some controlled acceleration testing. i'm curious for some hard numbers. (and i have too much on my plate right now to do it myself. :O )
Old 05-10-2006, 12:34 PM   #16
95metro's Avatar
After driving around with my
After driving around with my vacuum gauge installed I have noticed a few trends developing. Here are a few numbers for the curious observer:
Vacuum at idle is 18 in. Hg in warmer temps (13°C) with the engine fully warmed up.
The most common numbers during acceleration are 7 to 9 in. Hg...could be indicative of average mpg.
Exceedingly mild acceleration will yield 10 to 11 in. Hg, but I am subjected to dirty looks by drivers behind as they pull out and pass as soon as possible.
Cruising at 45 mph (65 km/h) seems to be yielding the best mpg - from 12 to 13 in. Hg on the gauge. Gauge will drop to 8 in. Hg on the mildest of inclines and idle or engine brake on the mildest of declines.
Wish I could do more pulse and glide driving, but there's too much traffic at most times.
Old 05-10-2006, 01:42 PM   #17
xB
The xB doesn't like lugging briskly, the Fuel Injection gets spastic if the engine is not reving in the 1500 to 2000 rpm range - the gearing is so low that the shifting time in each gear is only a few seconds and the computer has a hard time getting the settings right in that short of time so it feels mushy on the throttle response. I also notice that the MPG is pretty bad in the lower gears maybe they need breaking in more - the Geo would do the same thing usually the plugs needed gapping when that started happening. Best to keep the rpm low and sneak up on more throttle gradually and just wait for the speed to build. Adding a passenger yesterday and having damp weather sticky clutch and the seat a notch too far forward made for some really bad shifts and I really noticed the weight difference.
Old 05-10-2006, 01:58 PM   #18
95metro's Avatar
Bosch +2s or +4s are worth
Bosch +2s or +4s are worth it on small cars simply because you don't have to gap them. The +4s worked out to $17 for my Metro. Not bad for top notch plugs.
Where'd the graphs go?! Sonja Fuelly Web Support and Community News 3 02-10-2011 04:54 AM
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 04:48 AM
More Fuelly graphics? reppact Fuelly Web Support and Community News 5 11-30-2008 09:07 PM
apexing turns kickflipjr General Fuel Topics 10 04-14-2006 08:24 PM
