What Spark Plugs to use - Fuelly Forums
Old 02-07-2008, 04:05 AM   #1
Im going to change my spark plugs soon and i was wondering which ones to buy for the best fuel economy
domggg is offline   Reply With Quote
Old 02-07-2008, 04:52 AM   #2
101mpg's Avatar
What vehicle are you running?
I have had good luck with Bosch +4 platinum plugs in all vehicles I've used, but they do better in certain vehicles than others. In some vehicles you'll want iridium plugs, not in others. Tell us what you've got - it will help feedback.
Old 02-07-2008, 05:47 AM   #3
GasSavers_TomO's Avatar
If you indeed are running a Civic VX as shown in your vehicle log, then you want to run NGK V-Power ZFR4F-11 plugs.
Honda Civic VX Info/Links
Old 02-07-2008, 06:25 PM   #4
Lot of controversy about this topic. Usually people who use specialty plugs either are getting something they don't need or are having problems and using the plugs for a crutch.
Toyota recommends Iridium plugs in the Yaris. The Honda CRX requires conventional NGXs but I've done better with Bosch platinums, which I installed before I learned about the Honda Main Relay issue..
The Chevy uses NGKs and runs as well as can be expected for an old beat up car.
Gene
GeneW is offline   Reply With Quote
Old 02-08-2008, 01:36 AM   #5
sorry I have a 1994 honda civic vx
Old 02-08-2008, 01:52 AM   #6
GasSavers_Ryland's Avatar
Go with the stock NGK V-power plugs, I've tried number of differnt plugs including the Bosch +4 platinum, and my engine ran smoothest with the NGK, the only improvment that I could see is if you indexed your spark plug, pull a spark plug out and you will notice that it has almost a shadowing, put the open side of the spark plug twards the center of the flame with the arm of the spark plug in the shadow.
Old 02-08-2008, 02:39 AM   #7
Rower4VT's Avatar
I've run many different vehicles on both platinum and copper plugs and never noticed a difference in power or FE. For FE inprovement, you might just try messing with the gap of standard copper plugs in you engine. I went from a .44 gap to .52 (~20% increase) and my cold starting improved, cold idle is smoother, and I can shift at a lower rpm without the engine feeling over-stressed...i.e., more low end torque. I've only run a tank like this, but so far it seems to have improved the FE a bit...gonna fill up today and see what it comes to. The only catch is that if you're coil is weak or on the brink, it might have trouble firing across the larger gap...my coil is 14 years old, has ~200k miles on it and it works great.
[SIGPIC][/SIGPIC]
E85 ~$3.17/gal.
Rower4VT is offline   Reply With Quote
Old 02-10-2008, 03:49 PM   #8
guest001's Avatar
yeah, that's what I was going to ask about, the plug gap. that seems like it would have an effect on something. I could have swore I read that the expensive one last longer or are more prone to corrosion or something.
guest001 is offline   Reply With Quote
Old 02-10-2008, 10:39 AM   #9
any of you guys see the PULSTAR plugs ???http://www.pulstarplug.com/
superrican is offline   Reply With Quote
Old 02-24-2008, 01:53 AM   #10
I will say that there are definitely noticible gaslog differences in how different plugs perform, especially from 500rpm to 2000rpm's, but them pulstar ones have been debunked at least, at least in the higher RPM range. Now we need someone willing to spend the loot upfront to test them out hypermiling (and if they don't work, send the damn things back for sure)
http://www.teamzr1.com/ubbthreads/ub...at&Number=1976 - link debunking pulstar's at high rpms on dyno
-unknown
Oregon-Washington: Winter gas ending, summer gas formula starting? 740dan General Fuel Topics 5 02-26-2013 09:17 PM
miles between fuelup limit? drnknmnky13 Fuelly Web Support and Community News 6 09-14-2010 03:08 AM
Text box for the odometer? codemunky Fuelly Web Support and Community News 1 09-03-2008 12:12 AM
pulse up or pulse down a hill, higher or lower gear perris Hypermiling 9 07-16-2007 09:33 PM
Drafting behind a Truck GasSavers_roadrunner Hypermiling 20 12-23-2006 11:17 PM
