What oil to use? - Page 2 - Fuelly Forums
Old 05-08-2008, 08:56 AM   #11
Mayhim's Avatar
If you are limited by weight, then you still have to consider brand. Not all 5w-30s are the same viscosity.
The two thinnest 5w-30s that are easy to find are Havoline Deposit Shield and Castrol Syntec. The thickest 5w-20s are Castrol Syntec and Castrol GTX.
Old 05-08-2008, 11:27 PM   #12
unstable bob's Avatar
Send a message via AIM to unstable bob
Thumbs up
As far as your acetone question goes, the most common formula I've come across is 3 oz acetone per 10 gal of gas. And you should be fine if you want to try it in your Saturn w/ the plastic lines. That is a very common style of fuel delivery system...my Cavalier has it, and I've run boo-coo amounts of acetone through it w/o any probs. In fact, I've used an acetone/windshield washer fluid mix in an H20 injection set up that has plastic lines and a plastic reservoir w/o any probs.
unstable bob gable
AMERICAN ROAD WARRIOR!
www.unstablebobgable.com
1973 AMC AMX: The beauty
1987 Buick T-Type: The beast
unstable bob is offline   Reply With Quote
Help! AlfieGT Fuelly Web Support and Community News 1 05-23-2011 12:35 AM
Need help - my trip odometer was reset Keen4Green Fuelly Web Support and Community News 7 09-27-2010 07:27 AM
Mercedes Stop-start technology lunarhighway Automotive News, Articles and Products 0 07-30-2007 04:46 AM
Diesel chip Sludgy Diesels 10 12-10-2006 08:44 PM
TPS Will a 88 Civic DPFI TPS Work on a 92-95 D15z1 8Civic8 General Maintenance and Repair 2 11-09-2006 11:12 PM
