what oil do you use in your vx only! - Fuelly Forums
Old 05-08-2008, 01:06 PM   #1
mkiVX's Avatar
well after searching and searching it seems like every one has a different opinion
i have a 92 vx that i acquired at 150,000 and have been running 5w30 mobile1
i was wondering what is the lowest viscosity that i can run safely
please chime in if you own a vx or know about vx.
i live in the mountains/high desert are of california
to be exact Oak hills/ hesperia area
it gets pretty hot in th summer and below freezing in the winter
looking for better FE and how many more mpg do you think i will get with lower viscosity
thanks guys!
VX MASTER
SHWINN MOUNTAIN BIKE
GAS SAVER FAT BURNER
TOTAL MILES DISPLACED BY SHWIIN ON THE WAY TO WORK. 45 TOTAL MILES
mkiVX is offline   Reply With Quote
Old 05-08-2008, 02:21 PM   #2
slogfilet's Avatar
In my VX, I switched to Mobil1 0w30. I've only had the car for 3 tanks, so unfortunately I didn't have a baseline for the oil that was in it. I've been watching the level very closely, and haven't noticed any leaks.
slogfilet is offline   Reply With Quote
Old 05-08-2008, 02:44 PM   #3
jadziasman's Avatar
5W30 - whatever is on sale. Dang oil's friggin expensive now and I believe in oil changes every 3 months or 4000 miles. Used to use Mobil 1 on my first VX for ten years for 155K miles. So far no problems with mineral based oil this time - my 2nd VX probably has at least 200K now - rolled back odo very likely before I bought it in 2005.
Old 05-08-2008, 05:41 PM   #4
suspendedhatch's Avatar
Stick to the oil recommended by the manufacturer.
As for brands, Mobil 1 is one of the best but is also quite expensive. Valvoline conventional oil is good stuff and is more cost effective.
I run Mobil 1 5w20 full synthetic on my low mileage JDM engine (in my VX). If you run Mobil1, run FULL synthetic and the regular stuff, not the "high mileage" stuff.
Old 05-08-2008, 06:17 PM   #5
"In my VX, I switched to Mobil1 0w30"
I plan to do the same thing ('95 VX with about 106k).
Old 05-09-2008, 07:04 AM   #6
Danronian's Avatar
I'm running castrol synthetic 5w30.
Replaced the oil filter at 4k miles, and plan to change the oil at 8k miles. I've noticed the car starts up much easier now with this oil compared to the conventional I was using.
After 4k miles, the motor took only a 1/2 qt, mainly due to a valve cover and spark plug tube leak. The motor has 135k miles on it and the history is unknown. Installed it with 120k on it.
Old 05-09-2008, 09:01 AM   #7
Sigifrith's Avatar
I'm running Dino Oil now. Just finishing my 2nd clean cycle with Auto-Rx. Once the 2nd rinse cycle is done, I'll be back to Mobil 1 0W20 & Mobil 1 filter.
You can learn about motor oil here:
http://ferrarichat.com/forum/faq.php...tor_oil_basics
You can read about Auto-Rx at Bob is the Oil guy or the Auto-Rx forum.
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 05-09-2008, 09:06 AM   #8
EH3
EH3's Avatar
i agree completely
EH3 is offline   Reply With Quote
Old 05-10-2008, 06:54 AM   #9
GasSavers_Ryland's Avatar
I have 250,000 miles on my '92 civic vx, I used 0W 30 amsoil for the first few years I owned it (started at 204,000 miles), then I switched to royal purple 5w 30 and my idle bounce problem disappeared, it also takes about 10 seconds before the oil pressure light comes on after I turn the engine off, longer in the winter.
Old 05-11-2008, 07:59 AM   #10
smccall's Avatar
Mobil 1 5w-30 for me.
Where's the Jeep Wrangler forum? Revolution Fuelly Web Support and Community News 2 04-16-2012 09:40 AM
