What Mod Next? Larger Tb/wrap Header? - Page 2 - Fuelly Forums
Old 10-09-2008, 01:38 PM   #11
Sorry i just wanted to clarify that the header wrap doesnt improve the fe, as for the throttle body i drive like an old lady and dont get above 2500 like ever just figured more air the better.
as for the fan yea already have the electric fan it comes on at like 205 is that a good degree
JUSTIN
95 JEEP CHEROKEE XJ
HYDROGEN CELL
OTHER FREE MPG THINGS TOO
95CHERJUST is offline   Reply With Quote
Old 10-09-2008, 01:54 PM   #12
yea i wont do header wrap it will just rot them from inside out, as for the TB im still not sure on that yet
JUSTIN
95 JEEP CHEROKEE XJ
HYDROGEN CELL
Old 10-09-2008, 09:24 PM   #13
2000mc's Avatar
another no on the TB. the only time a larger tb helps is WOT at high rpm, unless youve done alot already to help your engine breathe, it might not even help at all.
the feeling of increased throttle response from a larger TB is in perception only. with a larger tb opening the throttle 25% way feels like opening a stock tb 30% or so.... because thats what its equal to in air flow. anyone that likes this throttle response would be better served stabbing the gas pedal a little harder and faster.
i've been there done that... few years ago,modded an 89 camaro about as fast as one could be w/ stock heads and no power adders. larger TB was the biggest waste of money i've had on any vehicle mod ever. i think i actually got worse mileage with the big tb. larger tb makes it more difficult to modulate the throttle because it lets more air in faster, twice as bad in an overpowered vehicle. i was always touching the throttle, tring to back off, coasting, getting on the throttle some...
big TB = bad idea
2000mc is offline   Reply With Quote
Old 10-09-2008, 09:25 PM   #14
civic lover's Avatar
Yep the wrap will ruin the header, because the header gets so hot that it will just erode.
civic lover is offline   Reply With Quote
Old 10-10-2008, 06:35 AM   #15
|V3|2D
thisisntjared's Avatar
... no i dont think thats it. the header wrap will hold onto moisture which will rot the header.
Old 10-10-2008, 11:47 AM   #16
I read some where that because the header gets so hot from the wrap it can't cool down enough, so the header is some what molten which makes it erode. You are correct too. It does hold on to moisture.
Old 10-10-2008, 12:08 PM   #17
Moisture means it depends on where you live. Here, humidity is regularly under 30% most of the year and I can tell you with utmost certainty that the wrap isn't holding on to ANY moisture at operating temps no matter where you are. So it's only a problem in moist climates I'd assume.
- Kyle
Can't delete fill ups posted by a friend. missmaispace Fuelly Web Support and Community News 4 08-18-2014 10:18 PM
km/l possible? Scottrates Fuelly Web Support and Community News 4 10-05-2010 11:14 PM
My version of a Grill Block GasSavers_TomO General Discussion (Off-Topic) 5 05-27-2009 08:57 AM
Cam regrinds for Atkinson cycle? omgwtfbyobbq General Fuel Topics 14 07-11-2007 07:03 AM
Honda 2005 1.8L i-VTEC 88HF General Fuel Topics 4 07-09-2007 06:40 PM
