What are the best LRR tire? - Fuelly Forums
Old 07-25-2007, 08:06 AM   #1
I've been searching around the net trying to find a list of the best LRR tires in terms of price, treadwear, and traction. I keep getting the Bridgestone B381, Nokian NRT2, and Sumitomo HRT 200 in my search. These tires, however, are not available in the size that I need (205/55/R16). Can anybody help me out in finding the best LRR tires in my wheel size?
slimreynolds is offline   Reply With Quote
Old 07-25-2007, 12:04 PM   #2
What if you go to a 60 or 65 profile tire, possibly in a narrower width?
Old 07-25-2007, 12:37 PM   #3
Send a message via AIM to Brian D.
Yeah, don't be afraid to play around w/the sizes a little...
Just don't screw yourself by winding up with a tire that rotates more than yours does in a given mile (that figure will/should be stated on a stats page for each tire...I know that tirerack.com does this). Also, be sure to check out that miata.net tire size calculator to find out what different sizes will compare to your stock tire size. Google those search terms that I just gave you and you'll find the page immediately.
GAS GSLR
Brian D. is offline   Reply With Quote
Old 07-25-2007, 12:57 PM   #4
brucepick's Avatar
I've seen the Michelin Energy MXV4 Plus mentioned as a LRR tire. I don't know what sizes are available.
I recently bought tires and did not have the funds for MXV4 Plus in the budget. I bought Kumho Solus KH16's from TireRack.com; they are a traditional design highway tread all season with 44 psi limit and a 440 treadwear number. Generally a higher treadwear number indicates lower rolling resistance as the higher treadwear comes from harder rubber compounds. FWIW.
Old 07-26-2007, 10:49 AM   #5
For my car (175/65/14R), the best LRR tire was the Goodyear Viva 2, and it also happened to be one of the cheapest tires. I got them at Wally World for 44 and change each.
I found my info on a web site, but don't have the link. They tested several brands.
Fuzzy5150 is offline   Reply With Quote
electric l/100km MJ/km Efried Fuelly Web Support and Community News 2 08-25-2008 08:41 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 08:27 AM
ScanGauge / MID... MetroMPG Hypermiling 25 09-10-2006 10:30 AM
Engine Builder's Notebook GasSavers_katman General Maintenance and Repair 8 07-13-2006 11:12 AM
My hard drive just crashed Matt Timion General Discussion (Off-Topic) 34 05-11-2006 04:55 AM
