Weight reduction: not filling the gas tank - Fuelly Forums
Old 08-23-2006, 04:21 AM   #1
krousdb's Avatar
Originally Posted by MetroMPG
As Dan knows, you can gain an equivalent weight advantage by just not filling your tank above half way.
Yup, about 6 lbs per gallon IIRC. When not calibrating the SuperMID, I only have 6 gallons max in my 11ish gal tank. That is about 30 pounds savings. I also have my windshield washer solvent at 1/2 tank max.
Old 08-23-2006, 06:05 AM   #2
I love it. Are you running half-tanks now, or are you still calibrating the MID with the VX?
I think 6lbs/gal is what I turned up most in a recent search I did as well. Which actually makes fuel the single heaviest easily "removable" item on my car. 10.5 gal tank = 63 lbs. Spare & jack = 24. Passenger seat = 29.
Old 08-23-2006, 06:13 AM   #3
how much difference does 30lbs really make??
for what its worth, i skipped breakfast this morning. figure it was worth a couple of pounds.
Free veggie starter kit!
argylesocks is offline   Reply With Quote
Old 08-23-2006, 07:28 AM   #4
25 lbs may represent a fuel economy difference of about 0.25% - 0.5% based on the oft quoted figure of a 1-2% fuel economy penalty for every extra 100 lbs carried (EPA).
The difference is likely too small to measure reliably with FE instrumentation in a test scenario. But it's real, and every little bit helps.
However, this kind of discussion is probably an example of how we apparently cultivate the impression we're Screwballs.
Old 08-23-2006, 09:58 AM   #5
krousdb's Avatar
I love it. Are you running half-tanks now, or are you still calibrating the MID with the VX?.
I'm calibrated and running half tanks now. Can't say it it makes a difference. Can't hurt though.
Old 08-23-2006, 10:09 AM   #6
Is dan back from retirement? Retirement meaning the beach.
Old 08-23-2006, 12:10 PM   #7
GasSavers_Jack's Avatar
I make up for full filling my by just running it 50 miles after the fuel light comes on!
See my car here:
Old 08-23-2006, 12:13 PM   #8
Modern cars are supposed to have closed systems. No fuel should evaporate to the outside, so you don't "lose" anything. Fumes are combusted via the evaporative emissions controls.
Old 08-23-2006, 12:17 PM   #9
kickflipjr's Avatar
I just go from F to E. I fill it up till it clicks (so I can track my mpg) and then ride till E (aprox. 9-10gal). If I do half fills it throws off the whole one click fill up thing.
2008 EPA adjusted:
Old 08-23-2006, 12:17 PM   #10
The only thing I've heard about too little gas is from lubedev/smartgas. He claims that all the water in that air will collect in gas and ruin your mileage! Logical, no?
Smart Metering Trend pb Fuelly Web Support and Community News 0 07-27-2008 04:03 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 02:18 PM
Coasting in Neutral Illegal??? 95metro Hypermiling 23 05-12-2006 06:50 AM
