"Warn" hubs on a Silverado 4X4 - Fuelly Forums
Old 08-22-2012, 05:57 AM   #1
Would there be a significant mileage improvement (enough to justify the expense) in my 1997 Chevy Silverado extended cab 4X4 w/ Vortec 5.7 gas V8 if I install "Warn" type hubs on the front axles? Or is it even possible? I am currently getting 13.2 around town, 99% pavement driving.
HaggardOldMan is offline   Reply With Quote
Old 08-22-2012, 07:24 AM   #2
IMO the negligible gain that you would get is not offset by the fact that's its a complete PIA to do the conversion. Not to mention the costs of the hubs.
kevinande is offline   Reply With Quote
Old 08-28-2012, 01:35 PM   #3
I used to have a Dodge 4WD pickup with manual locking hubs on the front axle. I didn't run extensive testing, but on those occasions when I did check I could measure no difference in fuel mileage with the hubs locked or unlocked. Leaving them locked kept the front axle oil seals from drying out and made use of 4WD much easier, because I didn't have to get out and lock the hubs.
Charon is offline   Reply With Quote
Old 09-04-2012, 02:10 AM   #4
I don't know about the gas engines, but with the Dodge Cummins diesel truck, people are seeing between .5 and 1.5 mpg gains. Yes, they are a pain to install, they are expensive but you get added fuel economy and they are cheaper to rebuild than replace worn out hubs. With that said, you can replace quite a few hubs for the cost of a spin free hub assembly.
machinemanrjb is offline   Reply With Quote
Old 10-08-2012, 02:12 PM   #5
You also need to check your o2's and ensure that you're not running rich. I had a 1998 Z71 4x4 5.7L ext cab and I got 15 no matter how hard I hammered on the gas. 16.5 highway at 75mph.
ZeroTX is offline   Reply With Quote
Old 10-08-2012, 02:14 PM   #6
That was with 33's too. Not stockers.
