wai question - Fuelly Forums
Old 04-19-2012, 05:40 AM   #1
wai question
is it possible to have the air too warm for fuel economy? has anybody experimented with temperatures to find an optimal temperature?
mikehallbackhoe is offline   Reply With Quote
Old 04-19-2012, 02:15 PM   #2
Re: wai question
Sure. If your intake air is too warm, you will start to get detonation, just as if your car is overheating. How warm is too warm? Depends on the vehicle. I have never experimented with different systems on the same vehicle. My short ram intake on my 2008 Civic Si served as a warm air intake. I saw intake temps soaring to 144 degrees F during 100+ degree weather last summer. That was as high as I got, and the car ran just fine. Power was slightly limited, but mpg was nearly 40 (car was rated at 29 highway).
Note: That Civic was a modern car with a premium fuel appetite (which helps mitigate detonation). The fact that it was a newer car means that it has knock sensors to help change ignition timing to keep detonation from occurring.
Old 04-19-2012, 02:17 PM   #3
GasSavers_Erik's Avatar
Re: wai question
Yes- you can end up with more spark knock if the intake air is too hot. I read somewhere that the 84-87 honda wai system was set up to run 100-110 degrees F.
Old 04-20-2012, 11:18 AM   #4
GasSavers_BEEF's Avatar
Re: wai question
I've had mine up to 179 with no issues but I run 93 octane (for other reasons) so that might help in my situation.
there was another user that had done the same (jangeo I think)
Average mpg + tracked km even though fuel-ups marked as missed Pelle Fuelly Web Support and Community News 14 03-04-2012 04:10 AM
consious driver. slurp812 Hypermiling 13 08-24-2011 09:07 PM
OBD2 scantools and engines JanK General Fuel Topics 3 11-14-2009 05:13 PM
new member dirtygst Introduce Yourself - New member Welcome 13 03-31-2009 07:46 AM
Column Shifter dletm08 General Discussion (Off-Topic) 6 03-30-2009 10:48 PM
