VX was repaired. Lots of adjustments made. MGPS question. - Fuelly Forums
Old 07-12-2013, 09:04 AM   #1
sebass's Avatar
Ok so my VX was repaired and mechanic said that keyway was bad and cam shaft and timing adjustments of firing were adjusted. Prior to repair compression on cylinders was low and way off so that's good now. Car runs but all those adjustments now made me nervous that my MPGS will suffer. Is lean burn tied in any way to what i just mentioned? Can those adjustments cause now my VX to be making CX or EX mpgs instead of VX mpgs? Any mechnics or people that know how can tell me if all the fixes can possible threw off mpgs now? Is mpgs or lean burn only tied to ECU (computer) and oxygen sensor only? I'm freaking out now.
sebass is offline   Reply With Quote
Old 07-14-2013, 04:30 PM   #2
VX_Arky's Avatar
Relax dude. Your car should run just fine now. You are drinking way too much caffeine.
VX_Arky is offline   Reply With Quote
Old 07-15-2013, 09:03 PM   #3
What Arky said,
You worrying about it will likely cost you more MPG then a timing adjustment. Bigger questions would be does it start ok? use any oil? do you notice any change in power?
Just drive it for a while and then check the MPG.
My experience is that most mechanics don't understand the VX nuances very well
SalorJOhn is offline   Reply With Quote
New guy from central illinois bbody69 Introduce Yourself - New member Welcome 5 04-11-2013 08:58 PM
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
