(VX/HX) 5-wire O2 Sensor Rcal values? - Page 2 - Fuelly Forums
Old 11-15-2008, 09:08 AM   #11
Member
1) 29.97k ohms
2) Its an NTK brand, but I don't recall where I got it, I think through a seller on ebay, not an auction, for around $120 if I recall correctly.
nowhhs is offline   Reply With Quote
Old 11-18-2008, 10:29 AM   #12
can you buy these rcals separately?
i have Walker 250-25001 and the rcals readings is off
3.00kOhms with a "h7y" printed on it
reallyslow is offline   Reply With Quote
Old 11-18-2008, 06:07 PM   #13
GasSavers_TomO's Avatar
^^^Not that I'm aware of. you could get some 1% tolerance resistors though and finagle them into the OEM connector. Or just use a potentiometer and set it so that you can feel lean burn kick in, but not "slam-your-head-into-the-steering-wheel" hard.
Honda Civic VX Info/Links
Old 11-20-2008, 12:03 AM   #14
i tried a walker in my vx and it ran really badly, nearly undrivealbe, the only way i could get it to smooth out was to bring up rpms or put it under load. i put the old worn out stock one back in and it runs fine, albeit not the mpg i want, i hover around 40 which is why i tried the walker.
GasSavers_Shaner is offline   Reply With Quote
Old 11-20-2008, 09:26 PM   #15
damn. i just realize that mine does that on the freeway right when i cruise around 3k rpm the car will slow down faster it should unless im putting under load
Old 11-21-2008, 07:43 AM   #16
June 11, 2009: EDIT: Bummer, The $99 o2 sensors are no longer available, they now have NTK-NGK @ $190, so the deal is gone ;( .
In the end I located a replacement L1H1 for $99 shipped that performs perfectly. The sensor is visually identical to the l1h1 oem Honda that was on my VX and is stamped made in Japan with an internal resistor. I ordered it from AutopartsDirectToYou.com here: http://stores.channeladvisor.com/Aut...t=5&scat=20363 and is Item 13208452 Honda Civic o2 Sensor
No CEL, plug and play, visually identical including internal resistor, jumped my mileage from 40.5 to near 45MPG and smoothed out the engine stumble at 1850RPM. I am freakin satisfied with this purchase.
fwiw, the sensor matches the readings posted in nowhhs post #11 above for the NTK brand.
SCoupe is offline   Reply With Quote
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
New Pickup Truck advice! 1993CivicVX General Fuel Topics 7 05-31-2008 01:58 PM
Lambretta DUE50 Scooter DarbyWalters Motorcycles 3 03-01-2008 05:49 AM
New Japanese Crap Request Thread SVOboy General Discussion (Off-Topic) 10 07-01-2007 03:34 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
