vx ecu questions - Fuelly Forums
Old 09-04-2008, 09:47 PM   #1
silversol's Avatar
vx ecu questions
i just finished up my cx to vx swap everything run great so far but i a still running the cx ecu. i still have to do the wireing and put the ecu in but i know there are two diffrent vx ecus the the one for ca models and one for the rest of the 49 states i would liek to know which one i have here are teh numbers. thanks in advance!
37820-p07-a00
670-101513
silversol is offline   Reply With Quote
Old 09-05-2008, 07:37 AM   #2
GasSavers_TomO's Avatar
you have the federal (lean burn) ECU there, first revision firmware in it. You're all set!
Honda Civic VX Info/Links
Old 09-05-2008, 08:02 AM   #3
Member
Does anybody have any idea what the difference is between a00 and a01 firmware? If I have both ecus, which I do, is there any advantage to running one over the other? I doubt the difference would be large enough to notice in normal variation, but if there is one I would prefer to use the more economical of the two. Thanks
nowhhs is offline   Reply With Quote
Old 09-05-2008, 09:21 AM   #4
silversol's Avatar
sorry to sound like a noob but what is first revision firmware?
Old 09-05-2008, 11:05 AM   #5
I don't know of any particulars in difference between the revisions (A00 and A01) as there really isn't any difference in gas mileage between the 92-93 (first revision A00) and 94-95 (second Revision A01). The big differences between the first year set and the second year set is: Dual Airbags for 94-95, "VTEC-E" embossed on the Valve cover for 94-95 VXs. 92-93 civics had black grills and foglight vents, 94-95 had only the black grills and color matched foglight vents.
The firmware differences were probably something minor as in haveing a smoother lean burn transition and idle control adjustments.
You'll be fine using either ECU, but if you have both, it would be cool if you could do a comparison between them.
What kind of mileage do you guys get with your VX? imzjustplayin General Fuel Topics 37 05-19-2008 12:59 AM
From Auto-X to Fuel Friendly, a ZX2 PHeller Introduce Yourself - New member Welcome 3 05-06-2008 11:34 AM
Better gas mileage for an RV 73challenger General Fuel Topics 5 10-31-2007 05:08 AM
Hi I'm Mike and I'm a Gasaholic... oneinchsidehop Introduce Yourself - New member Welcome 19 10-19-2007 03:45 AM
