VX cruising RPM increasing?! - Page 2 - Fuelly Forums
Old 01-12-2008, 04:43 AM   #11
Team GasMisers5!
landspeed's Avatar
If the clutch is slipping, then you can make it last for ages if you need to, just by matching engine speeds before using the clutch (except for 1st gear from a standing start, of course), and by using less power so it doesn't slip. Once it begins slipping, it heats up and the slip continues, so you have to ease off the pedal.
My original Bluebird had a slipping clutch, for about 2 years, but once it started, it never got any worse, due to my change in driving style
The danger of prolonging the lifespan of a worn clutch is that you can damage the flywheel, especially if the clutch fails suddenly at the end.
Hypomiler
Old 01-12-2008, 07:47 AM   #12
VX trainee
Yesterday I had to do a 180 on the highway (my wife forgot something), and noticed when I goosed it pretty good to get up to cruising speed, the tach jumped about 500 RPM for just a second. So it may be the clutch....anyway I've got a guy that's going to look at the brakes next week, will have him check the clutch out as well.
4bfox is offline   Reply With Quote
Old 01-12-2008, 10:01 AM   #13
Yeah... Definitely the clutch slipping then. If you floor it with the clutch engaged and the RPM goes up when the speed doesn't... Bad clutch.
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 04:13 AM
drivetrain resistance bagpipe goatee General Fuel Topics 9 09-14-2008 10:04 PM
Trade my 95 VX for a CRX HF! whychug General Fuel Topics 5 05-14-2007 08:39 AM
Ethanol-gas mix is a problem for Franklin ketel0ne Automotive News, Articles and Products 8 08-26-2006 09:36 AM
