VX = best hypermiler? - Page 3 - Fuelly Forums
Old 08-25-2007, 06:09 AM   #21
1993CivicVX's Avatar
Autozone... the same friend was telling to buy from them. I just assumed online would be cheaper than retail, but lifetime warrany? And I get to keep my left nut?! Win/win!
three stripes the charm!
Old 08-26-2007, 10:38 AM   #22
Your guy's odometers don't work when the car i off? Mine does? I dont put it into "on" position till I bump...
Old 08-26-2007, 12:40 PM   #23
Mine doesn't work half the time anyway--but it definitely doesn't work when the engine is off. Kind of annoying, because when I do get the odometer fixed, I'll have to immediately put the ignition back in the on position when coasting if I want to keep an accurate odo reading. But if the car only charges the battery while decelerating, then it won't be getting many chances to recharge! And that problem will be compounded by having the ignition in the on position while coasting, which drains more juice than having the ignition on accessories.
Old 08-26-2007, 01:43 PM   #24
Yep, autozone. I know a guy who replaced the clutch on his '91 accord, got the 135 deal and says the quality is fantastic. THis guy runs a garage, so I trust his judgment. I know where to go when mine finally needs replacement.
phantomcow2 is offline   Reply With Quote
Old 08-28-2007, 05:26 PM   #25
I have a 60 amp fuse going to my 2 amps, and its never blown, so its not kicka$$, but it draws a fair amount off the battery. Iv EOC'ed with headlights, wipers and the stereo blasting, no problems yet, but it is summer...
Originally Posted by brucepick View Post
Major loads would be:
Headlights, especially if using them with driving lights or fogs added. High beams aren't much more of a load than the lows - check the bulb wattages if you don't believe me.
Heater / ac / defrost fan. Check your fuse; mine is 25A!
Kicka** stereo, if you have one running.
Window defrost grid.
Old 09-04-2007, 09:33 AM   #26
the only problem of eocing a vx is that the O2 sensor cools down and it then takes longer to get back into lean burn. So I don't bother, I just coast a lot and drive at low rpm.
I got a few tanks above 60mpg, i havent put them on the gaslog yet. But usually I get around 50-55mpg in the summer. That includes hauling the family (wife and baby), jars, bags of concrete, sawdust, thrift store stuff, etc.
GasSavers_James is offline   Reply With Quote
Old 09-04-2007, 09:36 AM   #27
fuel economy forum
vegan recipes
green home improvement
honda gas mileage
Let the games begin! Matt Timion General Fuel Topics 4 12-12-2021 12:04 AM
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 11:54 PM
U.S. Cars Show No Fuel-Efficiency Gains in 2006 MetroMPG Automotive News, Articles and Products 3 04-26-2007 12:15 PM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 08:47 PM
