Guys and gals. Overheating will not happen unless you have a cooling system problem. If you completely block the grille your cooling fan will run a lot more but still keep the coolant temp in a safe range. You may see temp rise if you are sitting in traffic. Completely blocking the grille (assuming it eliminates all airlfow through the radiator may actually be counterproductive since your cooling fan will need more power to replace the electrical energy you are using.
An easy test for your radiator, with the engine running at operating temp, touch the top hose with your finger to get an idea of how hot it is, then touch the bottom radiator hose. If the bottom hose is not significantly cooler than the top hose your radiator is not removing the heat. It could be a loose water pump belt, but probably is in the radiator. If your radiator is 10 years old it has some blockage, after than it can get worse depending on age.
Summertime is radiator time with ambient temps contributing to the loss of reserve capacity in the radiator.
I found that most blown head gaskets were due to cooling system problems, that reached the point where the result is a blown head gasket.
If you are going to restrict airflow to your radiator make darn sure you have a good radiator to begin with.
regards
gary
