under drive pulley - Fuelly Forums
Old 01-27-2007, 04:02 PM   #1
under drive pulley
Anyone using an underdrive pulley?
What if any change in economy and relaibility and if anybody has used it long term?Is it a single or double pulley?
green swift is offline   Reply With Quote
Old 01-27-2007, 04:12 PM   #2
I remember using ud pullies on my mustang to slow down accessories to pick up a few more hp. not sure about how it would affect economy though.
metrompg did an experiment with taking the belt off his alt and picked up a lil gain in mileage, so i'd think it would be less than that since your still driving the accessories, but if you ud them all might be worth some gain.
Old 01-27-2007, 05:03 PM   #3
GasSavers_Ryland's Avatar
they alternator should start putting out 14 volts at around 860rpm (revernced from civic shop manual), so as long as you were able to keep it above that, and reduced electrical load, it should be fine, altho it might bog it down a little at idle as it wouldn't be putting out as many amps, but then you have to ask your self why the belt drive system is set up how it is? I suspect that droping your electrical loads at the same time would be required.
Old 01-27-2007, 05:58 PM   #4
ELF
ELF's Avatar
I have one on my truck,which has a big v-8, single pulley, I did not see any difference in FE or power. I think they really only help HP at high rpms by reducing drag. Maybe on a small engine the difference would be more noticeable.
Miscategorized cars. catching45 Fuelly Web Support and Community News 2 10-25-2011 04:44 AM
Nature's Air Conditioner ageispolis General Fuel Topics 0 08-16-2009 09:19 AM
Add an option to specify fuel grade and octane rating cyanics Fuelly Web Support and Community News 1 09-04-2008 07:40 AM
An idea on hiding google ads Matt Timion Fuelly Web Support and Community News 29 05-19-2006 03:49 PM
Honda - Which Head / Cam Combo? GasSavers_DaX General Fuel Topics 9 11-03-2005 12:00 PM
