umm, hows this possible? - Page 2 - Fuelly Forums
Old 04-30-2006, 12:02 PM   #11
Compaq888's Avatar
See, now I'm the same with
See, now I'm the same with you. Because I erased the 2 tanks where i was speeding like crazy my mpg went up .5mpg
Old 04-30-2006, 12:15 PM   #12
Matt Timion's Avatar
I'm unsure what good erasing
I'm unsure what good erasing the gaslog entries will do. In the long run it will all work out anyway, especially since the next fill up will average out the previous one.
Old 04-30-2006, 12:24 PM   #13
Compaq888's Avatar
Re: I'm unsure what good erasing
He used the pump error to boost his mileage. I used to do it too but the only person you screw is yourself
Old 04-30-2006, 12:38 PM   #14
The pump error will work the opposite way the next time around though. It will average itself out. Assuming this is true removing the pump error will actually hurt your gas mileage.
Old 04-30-2006, 01:21 PM   #15
Compaq888's Avatar
so that time I got 43mpg twice wasn't pump error???
Old 04-30-2006, 01:31 PM   #16
I think if you compare a .3
I think if you compare a .3 gallon fill up to a 10 gallon fill up, those two together will get rid of most of the pump error.
Old 04-30-2006, 03:10 PM   #17
I never said it wasn't a pump error. I said that the next fill up will average out the error.
Old 04-30-2006, 04:06 PM   #18
another factor to consider
another factor to consider at this time of year is thermal expansion in the fuel (cool nights, warm days - at least around here). it'll be particularly apparent when you try to fill an already full tank if the fuel has expanded at fill-up time.
if you want to calc the actual temperature/volume differences, go here for info: i used to have a figure handy (x% vol. change for every n degrees change, but i've forgotten).
http://www.users.qwest.net/~taaaz/AZgas.html#HOW%20GASOLINE%20IS%20SOLD%20IN%20CANAD A
Old 04-30-2006, 04:30 PM   #19
krousdb's Avatar
Re: See, now I'm the same with
OK, so does than mean that everyone can erase thier two worst tanks?
Old 04-30-2006, 04:37 PM   #20
Certainly not.
mpg help strega General Fuel Topics 16 12-10-2010 01:49 AM
iPhone location Jamie350 Fuelly Web Support and Community News 5 09-04-2009 12:11 PM
