Two cylinder cars - Fuelly Forums
Old 03-16-2006, 08:11 AM   #1
Two cylinder cars
I once owned a '78 Chevette and a '82 Ford Escort, each with 1600 cc, 4 cylinder engines. They made about 60 HP, and consistently got about 40 mpg highway. I was happy with them. So, 60 HP is enough power for small cars.
More modern engines are much peppier than the old engines due to 4 valve cylinder heads and fuel injection. For example, GM's 2800 cc 4 makes 175 HP. A twin cylinder 1400 based on this engine would produce almost 90 HP. Thats 50% more than my old Chevette 4!
2 cylinder cars should get mileage similar to hybrids at 2/3 the price. I'll bet that a 2 cylinder Chevy Cobalt would get well over 50 mpg.
Why can't Citroen or Honda build 2 cylinder cars again?
Old 03-16-2006, 08:17 AM   #2
Matt Timion's Avatar
My Honda n600 is 2 cylinder,
My Honda n600 is 2 cylinder, but it also is carbed and uses points and condenser.
I would love to put a water-cooled fuel injected 2 cylinder engine in that thing.
Maybe the only solution is a water-cooled motorcycle engine.
Old 03-16-2006, 08:22 AM   #3
Compaq888's Avatar
Don't motorcycle engines
Don't motorcycle engines make 150hp?? and rev past 12000rpm?
That is a good combo. But the problem is then you would need different gear ratios for the tranny. You can't just put a different motor and expect your gears to work right with the motor.
Some maxima guys are putting in VQ35's in their maximas that had VQ30's and most can't even use 1st gear.
Old 03-16-2006, 08:25 AM   #4
Re: Don't motorcycle engines
Just like car and truck engines, each one is different.
My n600 engine gets 35ish HP, and revs past 8000RPM if I push it. I imagine most 600cc engines have similar power.
Old 03-16-2006, 08:41 AM   #5
Yes, plus matt's engine is a
Yes, plus matt's engine is a motorcyle engine in the first place, if we get technical about it.
Anyway, any sort of transmission adapter plate can be built of the most part, you could prolly put and ITR tranny with LSD on the n600 if you wanted to spend the money to do it,
Old 03-17-2006, 06:41 AM   #6
Motorcycle engines
Motorcycle engines make lousy car engines.
Motorcycle engines (with the exception of Harley Davidson) are designed for high rpm power instead of low rpm torque. They do this by making the bore much shorter than the stroke, and by using a lot of valve overlap. Also, most motorcycle engines use carburetors, which are not nearly as good as fuel injection.
Putting a motorcycle engine in a car won't result in a big mileage improvement in a car.
Old 03-17-2006, 07:42 AM   #7
Re: Motorcycle engines
but it might result in a huge entertainment improvement in a car...
http://www.smartuki.com/
http://www.smartuki.com/Smart.wmv
http://media.putfile.com/Diablo-19mb
Old 03-17-2006, 08:13 AM   #8
kickflipjr's Avatar
NO
NO WAY!!!!!!!!!!!!!!!!!!!!!!
I was laughing like crazy with that last video. Talk about a sleeper.
2008 EPA adjusted:
Old 03-17-2006, 08:33 AM   #9
While we're talking about
While we're talking about sleepers...
http://video.google.com/videoplay?docid=6133912955628716829
Old 03-17-2006, 09:01 AM   #10
kickflipjr's Avatar
http://video.google.com/videoplay?docid=-4908181233385690454&q=minivan
this isn't as cool as matt's video, but it is a sleeper.
2008 EPA adjusted:
No MPG on next tank after partial fuel-up ? insightfulone Fuelly Web Support and Community News 1 04-18-2010 12:54 PM
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 07:41 AM
Retire a Vehicle pb Fuelly Web Support and Community News 1 11-11-2008 04:30 PM
Hey I'm a new member with a Festiva GasSavers_Kraig Introduce Yourself - New member Welcome 24 08-21-2006 06:17 PM
