08-28-2008, 07:29 AM
#31
Exactly, it's about displacement to load ratio technology allows.
But I'd say that most of the amazing technology we see on production cars right now was availible back in the 60's.
The Ford Cammer was making about 93hp per liter, and nearly 80 torque per liter. Not bad for a 7 liter engine. It was also carborated of course, and running mechanically/vacuum controlled ignition.
But it was also designed for leaded gasoline. Running it on todays gasoline the same exact engine would have to have reduced compression, robbing it of power... But if you replaced the carb with a good EFI system that also controlled the ignition, then the compression ratio could be kept where it was from the factory, making the same, if not more power.
Not bad for 60's tech eh? If rebuilt with low friction coatings (availible then, just not on production cars) then efficiency goes up. Add EGR functionality, and cruise efficiency goes up.
I bet if you took an origonal SOHC cammer engine and massaged it a bit you could see modern fuel efficiency out it, when comparing it to like sized engines (7 liters/427cubic inches).
These engines also had variable valve timing... Not electronically controlled, but they had it. Honda is noted for the first use of it on a production car because it was electronically controlled. It was an inherent feature of the engine, not just an add on. Ford designed it for nascar guys, so that once the car's tires and everything else was up to race temps they could squeeze some extra power out of it.
