Turbo Boost and FE - Fuelly Forums
Old 08-12-2008, 07:50 AM   #11
2 things to consider between a N/A and turbo motor. One is negative, the other is positive.....
1. exhaust restriction. The manifold is normally very short, creating restriction, plus the restriction in the body of the turbo, the restriction of the propeller, and any addition angles and turns that the exhaust must overcome to exit the into the exhaust system, plus the lost velocity that was used to turn the turbo hot side. Negative
2. Heat. Compressing air raises the temperature, hence the use in performance applications of an "Intercooler" (aftercooler), to remove heat. The additional heat on a turbo application, regardless of the the boost pressure, helps to atomize the fuel better, for a more efficient combustion efficiency. This is a built in hot air intake, so to speak. Positive
Ultimately, The heat from the turbo should help to overcome the restriction of exhaust, but it is a tight battle.
Backtobasics is offline   Reply With Quote
Chart suggestions jeadly Fuelly Web Support and Community News 0 08-08-2008 02:46 AM
Are these wheels worth it? Improbcat General Fuel Topics 17 05-24-2008 04:01 AM
92 Civic VX $1000 smccall For Sale 0 01-10-2008 05:11 PM
Hello from Turkey, Ankara Capcom Introduce Yourself - New member Welcome 3 12-06-2005 11:10 AM
