Turbo Boost and FE - Fuelly Forums
Old 08-07-2008, 06:02 AM   #1
Turbo Boost and FE
Hello. I was reasoning with myself last night (as any reasonable gassaver would do =P) If I had a car, with a 2.0L engine and a turbo. If I stayed out of boost, my gas consumption would be one of a 2.0L engine without a turbo correct? and only if I boosted then my FE would flush down the drain?
Thanks!
aych is offline   Reply With Quote
Old 08-07-2008, 06:13 AM   #2
To varying degrees, yeah. And it's definately better to have a 2L Turbo than a 3L non-turbo. But just to further complicate things for you, under some circumstances a little bit of boost can increase efficiency.
Dalez0r is offline   Reply With Quote
Old 08-07-2008, 06:31 AM   #3
Yeah, I'm a relative newcomer to the FE world, but I've been a performance nut for years. One of the early arguments turbochargers was that if you drive conservatively, you should be able to get slightly better gas mileage. The idea as I remember it is that even when not under boost, the turbo is spinning and it'll just barely overcome the parasitic drag of the fuel/air charge and any pumping inefficiencies of the engine.
GasSavers_Hal9000 is offline   Reply With Quote
Old 08-07-2008, 06:33 AM   #4
Folks with the 2.0t VW GTI report wildly varying MPG numbers, from 12 to 45 MPG without any hypermiling tactics. So, I'd say the answer to your question is yes.
Old 08-07-2008, 06:36 AM   #5
Greyg's Avatar
My turbo really doesn't do much until I'm over 2300 rpm's. If I'm driving for FE I rarely get my RPM's much over that. When you have boost you must have RPM's so you will, by nature of the beast, be getting poor FE. The best part of a turbo, I have the acceleration of a small V-8 when I need it and the FE of a 4 cyl.
Greyg is offline   Reply With Quote
Old 08-07-2008, 09:58 AM   #6
thats good news to hear! but now I'm wondering why do people complain about bad mileage on a gt-four. i'm planning to get one, but they run about 13L/100km mixed driving.. its a 2.0L turbo.
I'm guessing the 4wd also contributes to bad FE?
Old 08-07-2008, 10:27 AM   #7
GasSavers_BEEF's Avatar
I can see where there is an advantage to having a turbo but I can pretty safely say that your turbo car will probably never see what my car is getting (35.7 average) especially when you throw all wheel drive in the mix.
a turbo diesel will get realy good mileage and I guess in theory you could get better FE out of a turbocharged gas engine if it were smaller displacement.
I remember reading about chryslers slingshot. it was a concept car kind of sporty and tremendously small (by todays standards anyway) it had a turbo charged 3-cyl. it was a concept car that died. that was before the fuel price explosion though. back in $2 days.
Old 08-07-2008, 11:22 AM   #8
heck. i can't even get your mileage with my 88 camry 1.8L.
anyways. getting off topic..
so if i say i have 2 identical cars, except one has a turbo and one does not. Who'll get the better FE if driven identically?
I'm guessing at low rpm's the turbo and high rpm's the non turbo?
Old 08-07-2008, 11:23 AM   #9
If the engines are identical, the non-turbo one will probably do better. The whole reason turbos are associated with fuel economy is because you can use a smaller engine.
Old 08-07-2008, 11:42 AM   #10
If you have a 2.0L non turbo and a 2.0L turbo, the non will always get better fuel mileage. It comes down to compression ratio. A Turbo has a 8.5 to 8.7 to 1 compression. The NA on the other hand may have a 9.5 to 10.5 to 1 compression ratio.
More compression more HP at all throttle openings when boost isn't a factor. At any normal cruising speed the NA's throttle will be opened at a lower setting.
That 2.0L NA may make 150 peak HP where a Turbo 2.0L may make 200 peak hp. At 30 percent throttle the NA makes 90HP where the Turbo makes only 75HP. The Turbo only has an advantage in HP when boost is factored in.
GasSavers_ALS is offline   Reply With Quote
Chart suggestions jeadly Fuelly Web Support and Community News 0 08-08-2008 02:46 AM
Are these wheels worth it? Improbcat General Fuel Topics 17 05-24-2008 04:01 AM
92 Civic VX $1000 smccall For Sale 0 01-10-2008 05:11 PM
Hello from Turkey, Ankara Capcom Introduce Yourself - New member Welcome 3 12-06-2005 11:10 AM
