Trailer question - Fuelly Forums
Old 01-30-2007, 01:07 PM   #1
Trailer question
I am going to need to buy a trailer for longer trips. The trunk in the Fiero just isn?t big enough. I need a trailer that can hold 2 suit cases. I have had some people recommend that I get one of the small trailers people pull behind motorcycles.
What would be the best kind of trailer FE wise? Are there certain ones that would create less drag or assist in aerodynamics?
GasSavers_Lincoln is offline   Reply With Quote
Old 01-30-2007, 01:13 PM   #2
What about just a small platform that mounts to the trailer hitch, then lash the suitcases to that?
northboundtrain is offline   Reply With Quote
Old 01-30-2007, 01:22 PM   #3
I thought about that as a back up plan.
I would have to relocate the license plate and be careful not to block the tail lights.
I wasn’t sure how far past the bumper the platform could stick out.
The back of my car is always black with dirt, so the suite cases would have to be put in a couple of garbage bags.
Old 01-30-2007, 07:50 PM   #4
lovemysan's Avatar
I'd put a luggage rack on it. You have to license a trailer- more bother and expense and less maneuverability.
You just want people to have a luggage rack because you have one.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 01-30-2007, 08:09 PM   #5
skewbe's Avatar
If you lift up the trunk a little, you could pull a tie down strap or two under the narrow part of the trunk and maybe another going front to back and cinch it all down between your air intakes right behind the window. Pretend you're a hatchback Just don't block the air intakes.
Standard Disclaimer
Old 01-31-2007, 11:09 AM   #6
Team OPEC Busters!
GasSavers_Brock's Avatar
I have one of those platforms that fit in the receiver hitch. It works out really well. It is just over 4 feet wide and 20 inches deep. We use it mostly for hauling larger dirty things. I had planned on getting a larger "deck box" or something similar that would fit on it for trips to throw stuff in that to protect them. I hadn’t thought about the license plate issue :0
Old 01-31-2007, 03:18 PM   #7
lovemysan's Avatar
Something like this would be good
http://www.uhaul.com/trailers/sport-trailer-360.aspx
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 01-31-2007, 03:46 PM   #8
Originally Posted by lovemysan View Post
That would be perfect. I'll have to see if U-Haul sells them.
Old 02-01-2007, 01:31 AM   #9
little guy trailers
google little guy teardrop trailers. the company is called little guy
they make some cool stuff and some of the larger ones can sleep two people or try..... golittleguy.com
95_corolla is offline   Reply With Quote
Old 02-01-2007, 09:51 PM   #10
GasSavers_Ryland's Avatar
I talked to a guy who had a TDI, and a motorcycle trailer, he said that of the trailers he's owned, that he really liked the rubber torsion bar suspention, as it acted as a dampener as well, and that with a light trailer like this, that it was important to have that dampening, I think he said mpg decrease was less then 10%
Hyundai Active Eco System DurhamRich General Fuel Topics 4 05-25-2012 01:46 PM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 06:37 AM
Plug wires zpiloto General Fuel Topics 22 06-05-2006 06:15 PM
Need some job advice Compaq888 General Discussion (Off-Topic) 10 05-23-2006 09:13 PM
I issue a challenge!!! Matt Timion General Discussion (Off-Topic) 32 01-29-2006 06:28 PM
