Tornado Air Management Systems - Fuelly Forums
Old 06-28-2007, 08:37 AM   #1
Does anyone know if the Tornado Air Management Systems will really increase a car's mileage results by 10% plus?
ljeffries is offline   Reply With Quote
Old 06-28-2007, 09:14 AM   #2
brucepick's Avatar
I hope you didn't already send them your money.
Old 06-28-2007, 09:19 AM   #3
brucepick's Avatar
Look in articles.
Read everything in the glossary.
Learn about driving with load, FAS, EOC, codfish.
Recognize that you'll get better mpg at 10-15 mph slower than whatever speed you've prolly been driving even if you change nothing else.
Pump your tires to the max stated on sidewall labeling. Or a few pounds over if you dare. Make sure they're at that pressure when cold in the a.m. before starting up. Usually that means pump them to a few pounds over max sidewall, then check in the a.m. and adjust if needed. Next time you buy tires make sure they're rated at least 44 psi, maybe 50+ if you can.
Put in a clean oem type air filter. Forget K&N. For max FE you're going to be using less fuel-air mixture, not more.
Old 06-28-2007, 10:15 AM   #4
its junk. nuff said
Old 06-28-2007, 10:50 AM   #5
If it would do that then the car manufacturers would put them in at the factory. Sorry.
Old 06-28-2007, 11:10 AM   #6
http://fuelsaving.info/turbulence.htm
Old 06-29-2007, 01:59 AM   #7
Send a message via Yahoo to GasSavers_BMac
No they wouldn't!
My friend had one in his chev 1 ton catering truck. Driving in on a route day after day he saw a 1.5mpg decrease and go this money back!
My opinion - it may work in SOME engine intake designs but NOT all of them!
1998 Dodge Dakota Sport 5.2 auto,
Aero Cap,
Cam advanced 4 degrees,
MSD 6TN,
MSD Blaster2 Coil,
MSD 8.5mm SuperConductor wires,
Borg-Warner cap & button
Halo plugs,
PCV jar
and more to come...
GasSavers_BMac is offline   Reply With Quote
Old 06-29-2007, 07:39 AM   #8
Yeah, that's why they don't put them in at the factory.
Old 06-30-2007, 02:54 PM   #9
GasSavers_maxc's Avatar
They only work on some Fords. You put a smaller one in on some Chryslers than what they say then they work.
less lurking and more working
Best Diesel in N. Texas? JudisJetta General Fuel Topics 7 05-28-2010 08:55 AM
What is this stat? cavale Fuelly Web Support and Community News 1 09-03-2008 07:23 AM
