03-20-2006, 12:54 PM
Re: YEs you hAvE
Originally Posted by JanGeo
Yes you have misunderstood - the drag coefficient is the factor of the streamlineness of the shape i.e. square box vs teardrop but that has only a small influence on the aerodynamic drag - the more important factors are frontal area first and rolling resistance due to weight second. This is why the really fast sportcars are very small and low to the ground, pointy or not they only go fast because of their small frontal area and a few extra HP as well of course. Once you get up over 150mph then the shape becomes more important as well as surface treatment.
The formula for calculating drag contradicts what you are saying. CD*A*RHO/2*V^2. The CD and frontal area are EQUAL factors. Since they are multiplied by each other, you could decrease either by a certain percentage with the same results. Also, since aero drag increases at the rate of velocity squared, both CD and FA are much much much more significant than rolling resistance at speeds over 40MPH.
