To get more FE...drive faster? - Page 2 - Fuelly Forums
Old 09-06-2007, 04:51 AM   #11
Originally Posted by Telco View Post
Your engine is far more efficient at whatever RPM you are at 80MPH than at 60MPH.
Most gas engines likely create more hp per unit of fuel as top gear (highway) speeds increase and the engine is run closer to its BSFC peak, but that's not quite the same as saying "your engine will use less fuel at 80 mph than at 60 mph".
Modded V8's / drivetrains are going to have very different BSFC maps.
I still find it hard to believe that a 5-speed 4-cyl Accord uses less fuel at 60+ mph than 50, steady state.
Old 09-06-2007, 05:50 AM   #12
Quite Possible
Hi Folks,
Although I'm new here, I do believe that what the original poster is saying is quite possible. Let's look at a simple scenario - How do we get 30 MPG:
1) Travel 30 MPH at a flow rate of 1 GPH
2) Travel 60 MPH at a flow rate or 2 GPH
3) Travel 80 MPH at a flow rate of 2.67 GPH
So, from case 2 to case 3 the fuel flow increases 33%, but he's gotten there 33% faster, because he's going 33% faster. That's the simple case. Now let's complicate it a bit.
When you increase the velocity, the drag increases as a square of that. However, maybe the engine and tranny also runs more efficiently at the higher RPM, so that it counteracts the increased wind resistance. The end result may be that the increased efficiency overcomes the increased drag (i.e. the flow rate doesn't increase linearly with the speed of the vehicle).
It's not that he's using less fuel at 60+ mph. It's that he's getting more distance out of the increased amount of fuel he's using, which changes the MPG ratio.
How can you scientifically test this?
Start at point A, drive to point B at an average speed of 75 MPH, then drive back. Measure the fuel economy. Then start at point A, drive to point B at 55 MPG, then drive back. Do both trials under the same conditions. Post your results.
You can also use a ScanGuage to watch your fuel efficiency, but that's already been said, and IIRC you have OBD1, not OBD2, so that won't work for you.
Cheers,
Joe
J. Hartley is offline   Reply With Quote
Old 09-06-2007, 06:26 AM   #13
I think the main thing to consider is the trip...
My best tank ever was on a full highway trip drafting a bus...
If you do the same exact trip slower than you could compare your mpg. But comparing my highway trip where there is no stop and go traffic, not having to warm up the engine etc, to my daily commute is no comparison.
My Photosite My Photoblog
bbgobie is offline   Reply With Quote
Old 09-06-2007, 07:00 AM   #14
You didn't say anything about the automatic tanny: Does it have a lock up torque converter? If it doesn't, there could be a lot of torque converter slip at lower speeds, and this would torpedo your mileage at low speeds.
A similar thing happens in my F350. The torque converter will simply not lock up under about 45 mph, no matter how much I baby the throttle.
I've been looking for a chip to reprogram the tranny, but no luck so far.
Old 09-06-2007, 07:02 AM   #15
omgwtfbyobbq's Avatar
It can, but this tends not to happen with a couple exceptions. Big vehicles with big engines and auto trannys, since getting the tcc to lock up can really increase efficiency, and may not happen at lower loads. And... relatively aerodynamic cars with really big engines and manual transmissions, since the change in BSFC compared to load can match or outpace the change in energy compared to speed. However, just about every other car/engine combo out there can and probably does have a drop in efficiency wrt over most of it's OD/top gear range.
Old 09-06-2007, 07:26 AM   #16
mrmad's Avatar
My CRX is getting the same FE at an average of 75mph on the fwy as it did when I was averaging 65mph. This is averaged out on multiple fillups, so I can only conclude that the HF engine is more efficient at 2500 rpm then it is at 2000 rpm to make up for the increased drag.
Old 09-06-2007, 07:34 AM   #17
It's not related to engine speed much, if at all. It's related to engine load. Provided your statement is in fact correct, since I'm not there to verify it and I have no way of knowing what you are and aren't controlling for.
Edit- I'ma callin' BS. A stock 49 or CA HX should have near ideal gearing. Imo there's no way it'll get exactly the same FE at an average of 75mph compared to 65mph provided a controlled test.
Old 09-06-2007, 07:44 AM   #18
It's not inconceivable at all. My Dodge van with 360 got its best FE at 70mph. I could never break 15.5 @ 55, 60, or 65mph, but at 70mph I was pulling nearly 17mpg.
'00 Echo - DD
'11 Kia Rio - Wife's DD
Old 09-06-2007, 07:47 AM   #19
mrmad's Avatar
It's not related to engine speed much, if at all. It's related to engine load. If you regear appropriately, the car will likely start getting better mileage at lower speeds. Provided your statement is in fact correct, since I'm not there to verify it and I have no way of knowing what you are and aren't controlling for.
I think it has alot to do with rpms as the cam timing and intake manifold resonances are rpm related. At 2500 rpm, it may be running more efficiently because of this.
Old 09-06-2007, 08:16 AM   #20
Could be... But not according to every singe BSFC map I've ever seen. I've never seen an engine geared properly that will increase efficiency by 30% if it's already near or greater than half load and minimal BSFC. Course, it could be that Honda designed a weird engine unlike any other engine, but if I had to pick between that and a lack of consistent testing on your behalf, I'm sure you can guess which one I'd pick.
google+ integration? xchrislee Fuelly Web Support and Community News 3 07-15-2011 01:55 AM
Automatic Civics? suprapsu Transmissions and Running Gear 29 07-14-2008 11:38 AM
1992 Honda VX cfg83 For Sale 7 03-03-2007 12:08 PM
GasSavers.org Stickers Matt Timion Fuelly Web Support and Community News 7 10-12-2006 03:48 PM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 03:31 PM
