Tire/Wheel size's question - Page 2 - Fuelly Forums
Old 06-14-2006, 06:27 AM   #11
Wink
Originally Posted by krousdb
Not less mass. The I14" Insight tire weighs less than any 13" tire.
The Insight tire is a special tire, but for each tire manufacturer's brand/series of tire, a narrower tire is lighter. Find good tire mass and diameter information at.
http://www.tirerack.com/
Old 06-14-2006, 06:37 AM   #12
http://www.tirerack.com/tires/Spec.j...e1=yes&place=0
An even narrower tire is available, 155-80 R13. It has a diameter of 22.7, as opposed to a 175-70R13. The 155 tire weighs 1 pound less.
Old 06-14-2006, 10:54 AM   #13
Matt Timion's Avatar
Upping to larger tires is essentially the same as getting a longer geared transmission. The downside of this is that your odomoter/speedometer will be affected as well. Your odometer/speedometer is calibrated to stock tire size, so you might end up being a little off (3% or so) so you might have to adjust your MPG figures each time you calculate them.
Then again, I upgraded to 185s (175 stock) and my speedometer/odometer is right on (I tested with a GPS unit).
I would go with LRR tires or more narrow tires before thinking of getting new rims.
Old 06-14-2006, 11:04 AM   #14
krousdb's Avatar
The 155-80-R13 you mentioned are 14 lbs. The 165-65-R14 Insight tire is one pound less, 13 lbs.
http://www.tirerack.com/tires/Spec.j...l=Potenza+RE92
Old 06-14-2006, 11:46 AM   #15
http://www.tirerack.com/tires/Spec.j...e1=yes&place=1
This 155-80R13 tire is only 12 pounds. Neener, neener, neener...... LOL
Old 06-14-2006, 12:29 PM   #16
krousdb's Avatar
But not LRR.
Top 5 (non-hybrid) economical cars! Draigflag General Fuel Topics 15 03-25-2013 03:31 AM
Hyundai Active Eco System DurhamRich General Fuel Topics 4 05-25-2012 01:46 PM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 06:37 AM
Plug wires zpiloto General Fuel Topics 22 06-05-2006 06:15 PM
I issue a challenge!!! Matt Timion General Discussion (Off-Topic) 32 01-29-2006 06:28 PM
