tire tread type and FE - Fuelly Forums
Old 11-07-2007, 12:45 PM   #1
Member
dletm08's Avatar
My 99 Silverado 5.3L (hardly a gas saver) came with Off Road tires on it. They are loud and vibrate alot. I figure they certainly cannot be helping my FE.
Does anyone know if a Highway tread would help FE much.
for the record
I currently get 15-17mpg.
dletm08 is offline   Reply With Quote
Old 11-07-2007, 01:17 PM   #2
Absolutely. In my previous Honda, I saw fuel economy differences of 5% - 13% among various highway tires, which meant some had lower rolling resistance than others. So if you go from an off road tire, which is almost certainly not a low rolling resistance (LRR) tire, to a highway tire, you should see significant FE improvements. And if you specifically select a LRR highway tire, the improvement should be even more substantial.
Check out the Nokian WRSUV to see if it's available in your tire size:
http://www.nokiantires.com/en/tire_w...?season=summer
It's a LRR tire. I went through 2 sets of Nokians on my previous Honda (not the WR). Great handling, long tread life, LRR. Best tires I ever used. If you buy the Nokians and inflate them to the maximum sidewall pressure (likely 44 psi), I'll bet you'll get 15%+ better FE than you are now.
cems70 is offline   Reply With Quote
Old 11-07-2007, 01:39 PM   #3
bones33's Avatar
The BFGoodrich Long Trail has a low rolling resistance and not very agressive tread. I'm pretty sure the greenseal.org report lists it as doing well. Do a search for 'LRR tires' to find it.
bones33 is offline   Reply With Quote
Old 11-07-2007, 03:02 PM   #4
DarbyWalters's Avatar
Michelins...XGT I think
2006 Jeep Liberty CRD...Founder of L.O.S.T.
DarbyWalters is offline   Reply With Quote
Old 11-07-2007, 03:56 PM   #5
SL8Brick's Avatar
I'd go with a Highway All-Season tire on a Silverado. Like beatr911 mentioned, the BFG Long Trails are pretty nice. I had them on my old S-10 p/u. They did loose traction rapidly when I was down to 5/32nds, however. The Yokohama Geolander H/T-S G051s are another nice choice, IMO. You may not be able to reap the full benefits that a passenger car would w/LRR tires....but its a good start!
1993 Volvo 240 Wagon - 323k miles (awaiting recommissioning)
1999 Audi A6 Avant Quattro - 149k miles(the NEW daily driver)
SL8Brick is offline   Reply With Quote
Old 11-08-2007, 02:37 AM   #6
LRR tires is a good start. but,even @ 5 or 10% gain, you won't see much in your FE w/ that vehicle.
look in the archives for truck threads. grill block, airtabs,driving techniques, etc will help you as well.
Old 11-08-2007, 09:39 AM   #7
The knobby off-roaders generally have a high resistance. Comsumer Reports has the latest report on tire RR, but you have to pay to use it.
I have Michelin MXV-4 "Green-X" LRR treads on the 'Teg. Overpressure and this tread design really helped boost FE. Judging from my Gaslogs, I would say that it helped in the 5-10% range, plus or minus. They're a bit pricey, but I don't worry so much putting 50 psi in them. One-year of use and they're great.
Best FE...
RH77
Old 11-08-2007, 10:15 AM   #8
izzat so?
glad i didn't mention acetone. <looks around for flying rocks>
anyway, there are things in addition to driver mods that MAY help.
as previously stated, "if something works for you continue using it, if not then stop."
Old 11-08-2007, 03:54 AM   #9
I put narrower tires on my F350, and it seemed to help about 1 mpg or so. The original tires were 265 75R16 BFG Long Trail. The new tires are Michelin 235-85R16 M&S tires. The new tires are a tad taller, just 0.3". They don't have a very aggressive tread, but they did well last winter. Never got stuck.
I'm going to northern Maine next week, off road. I hope they do OK on muddy and snowy dirt roads.
Old 11-08-2007, 08:07 PM   #10
Danronian's Avatar
Back on topic a little...
Where would someone find a list of the rolling resistance of tires or a list of Low Rolling Resistance (LRR) tires?
Reconciling the first fuel-up in a new vehicle AzRobbins Fuelly Web Support and Community News 6 06-21-2011 04:29 AM
Uploading old fill up info Electra225 Fuelly Web Support and Community News 2 05-20-2011 08:29 AM
Pump Police tomauto General Discussion (Off-Topic) 1 11-17-2006 01:50 PM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 03:31 PM
City vs. Highway Routes 95metro General Fuel Topics 6 05-15-2006 12:44 AM
