Tire size question - 1996 Saturn SL2 - Fuelly Forums
Old 06-26-2007, 04:32 PM   #1
My Saturn ('96 SL2 1.9l DOHC) calls for a 185/65-15, my car has 195/60-15 on it currently. Could this wider although stiffer tire cause the fuel economy to drop by 1-2 MPG? I'm just curious, if this is the case I might consider switching to some thinner LRR tires sooner than later.. Of course being hasty would incur a cost that would take a long time to recoup in saving a few MPG's.
My original thread w/ fuel economy is here: http://www.gassavers.org/showthread.php?t=4095
rearviewmirror is offline   Reply With Quote
Old 06-26-2007, 04:49 PM   #2
yep.
Old 06-26-2007, 07:57 PM   #3
lovemysan's Avatar
185/65/15 is a hard size to shop for. I'd wait for your current tires to wear out. Someone probly upsized the tires because the correct size was not available. Its not hurting much.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 06-26-2007, 08:19 PM   #4
That's exactly what happened, my friend owns a shop, they had those in stock, I get them for next to nothing so I said go for it. That was ~20k miles ago so another 20k and I can replace them. It wouldn't be a wise investment to ditch them now as it would take forever to make up the cost. I wonder it changes the tire inflation though. The 185's called for 32 front, 26 rear, I am running 35 in all 4, the max inflation is 44PSI. I wonder if I can still step it up a bit.
Old 06-26-2007, 10:57 PM   #5
cfg83's Avatar
rearviewmirror -
Yeah, definitely keep your tires until you've worn them out. There is a really good tire-tech website that I can't find right now that says something like "if all else fails, apply the 10% rule". Take the max rated PSI and subtract 10%. In this case, 44 PSI - 4.4 lbs = 39.6 => about 40 PSI. If you do that, you should get MPG benefit without having to worry about over-inflation.
iphone experience bearmeister Fuelly Web Support and Community News 5 02-10-2010 11:25 PM
Neutralizing Our Environmental Impact SVOboy General Discussion (Off-Topic) 9 09-01-2006 07:23 PM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 04:38 PM
hello GasSavers_nathan Introduce Yourself - New member Welcome 3 12-07-2005 04:59 PM
First coat of paint is on!!! Matt Timion General Discussion (Off-Topic) 12 10-03-2005 08:50 AM
