Tire size, impact on the tach? - Fuelly Forums
Old 12-27-2007, 04:47 AM   #1
So I have a set of 155-80-13 tires on my VX, and the corect size 165-70-13.
I'm wondering if this got any effect on the mph and the rmp display on the tachometer?
Old 12-27-2007, 05:07 AM   #2
GasSavers_SD26's Avatar
Tach measures engine speed, so that will remain unchanged. Speedometer speed, yeah, that is a variable.
But manufactures do not always have accurate speedometers. Easiest thing to do is to check your actual ground speed with a GPS unit. We did a tire change on the Focus to a taller tire with the same width making the circumference larger, and that made the speedometer spot on. One of my other cars reads about 2MPH optimistic.
Dave
Old 12-27-2007, 11:19 AM   #3
kamesama980's Avatar
they're 3% larger so the speedo will read 3% faster (this is relative to the old tires NOT absolute (correct) speed) that means that at 100 mph it'll read 3 mph fast and at lower speeds it'll be proportionally less.
At the same time though, that's within the realm of bald vs new tires
-Russell
Old 12-27-2007, 04:43 PM   #4
hahaha so I'm going slower than 55mph, thats maybe why I'm getting so great FE.
thx for the info, and yes I was talking about the speedo and not the tach... thx
Old 12-27-2007, 05:58 PM   #5
Um yea...53.5 mph...big difference.
-Russell
Old 12-27-2007, 06:13 PM   #6
cfg83's Avatar
BIBI -
Yup, a GPS is the way to go. Here are my results :
New shoes (aka tires)
http://www.gassavers.org/showthread.php?t=3699
Optionally, you can use this calculator :
Miata.net Tire Size Calculator
http://www.miata.net/garage/tirecalc.html
Or this one :
the wheel & tyre bible
http://www.carbibles.com/tyre_bible_pg2.html
iphone experience bearmeister Fuelly Web Support and Community News 5 02-10-2010 11:25 PM
Performance Underdrive Pulleys? cfg83 General Maintenance and Repair 10 09-08-2007 09:04 PM
4 VX wheels for $100 in Chicago area McPatrick For Sale 2 07-17-2007 04:46 PM
NMG (Sparrow) owner "first 1000 miles" report MetroMPG Electric and Solar powered 8 03-25-2007 08:22 PM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 04:38 PM
