I concocted a splitter using various fittings to make it automatically balance with my compressor's built-in tank and still have a connector for whatever accessory/hose I want to attach to use the air.
+1
Can you tell I like quick-connect couplers?
In truth, I rarely leave the tank hooked up. I connect them together, open the valves so they equalize (which generally kicks on the compressor pump, bringing them up to around 115 psi), disconnect and use the 5 gal tank to fill tires or sometimes to take off lug nuts with an impact gun. The coupler on the T union only sees action if I'm using some kind of high-demand air tool, though even then I've been known to get more creative:
That's my crank pulley bolt remover, BTW.
