Tire pressure difference - Page 5 - Fuelly Forums
Old 01-08-2012, 11:41 AM   #41
guest001's Avatar
Re: Tire pressure difference
The only effect I've experienced is slight center wear. It is harmless...the center isn't bald yet when the other 90% of the tread width is down to the wear bars. More severe center wear would still be harmless in my opinion, water will still be channeled away by the non-center areas the same either way.
I've been doing this for a long time with a lot of miles on a lot of tires and that's been my experience.
you mean the center is bald and the outsides are at wear bars?
guest001 is offline   Reply With Quote
Old 01-08-2012, 12:55 PM   #42
No, I mean the center isn't bald when the outsides are at the wear bars.
The center reaches the wear bars when the outsides are just a hair above the wear bars; the center gets partly into the wear bars when the outsides reach them. By the time the center is bald there's barely any visible tread left on the outsides.
Old 01-08-2012, 02:45 PM   #43
I had the same observation on center wear.
I have had some slipping on wet pavement. It mostly when starting from a stop on an incline. I backed off on the pressure when it seemed a common occurance. Now it's likely do the tires' worn tread.
Old 01-09-2012, 04:46 AM   #44
........Impact failures and blowouts cannot be caused by overinflation. We're not talking about bicycle tires here. Impact failures happen when the impact compresses the tire until the sidewall is cut by the rim; increased pressure increases protection against that.......
That's only one of the types of impact failures - and this is more a phenomenon of low aspect ratio tires.
The other type of impact failure is when the tire encounters an object and the cords break from the force of that impact. If the inflation pressure is higher, then the tension on the cords is higher - ergo, the cords require less force to break.
Capri Racer
Visit my web site: www.BarrysTireTech.com
CapriRacer is offline   Reply With Quote
Old 01-09-2012, 05:52 AM   #45
Interesting. Nobody's mentioned that type of failure before and I've never read about it but it sounds plausible. What about the impact causes the cords to break?
Every impact failure I've ever had (and I used to have a lot before I tried higher pressure) was snakebite-style and they did not discriminate by aspect ratio, but it's not impossible that my experience has been atypical.
Old 01-09-2012, 08:17 AM   #46
I have ran high inflation pressures in our Honda Fit since it was new. We now have almost 29,000 miles on it, and our tires probably have 20,000 miles left on them. My father-in-law has run the recommended pressures in his Fit since it was new. He replaced the tires at 33,000 miles (and I would have replaced them long before then, as they were completely bald).
*SHRUG*
Old 01-10-2012, 03:50 AM   #47
In both impact types, the cords break because they exceed their breaking strength. In the case that is tied to low inflation pressures, the tire bottoms out and the cords are bent quite severly thereby breaking the cords.
in the other, the force of the impact itself is what breaks the cords - and obviously as the inflation pressure increases the force of impact goes up as well.
There is a photo of this type of failure here:
http://en.wikipedia.org/wiki/Blowout_(tire)
Capri Racer
Old 01-10-2012, 05:29 AM   #48
That photo, embedded:
Yikes. I've never seen that kind of failure before...only sidewalls that have been cut between the road hazard and the rim and high speed low pressure sidewall blowouts. Is that common for other people?
Old 01-10-2012, 06:30 AM   #49
First I've seen it.
Except for once clipping a curb in what most wouldn't call a blow out, I've been lucky on that front, and some nasty potholes can appear in PA roads. One, on higher pressures, threw the Ranger's alignment out. Including the rear wheel's by a smidge (noticable on the report, but still in spec).
Old 01-10-2012, 09:15 AM   #50
tradosaurus's Avatar
That would still be covered under Discount Tire warranty.
tradosaurus is offline   Reply With Quote
'95 Honda Civic DX hatchback w/ VX tranny pinging cems70 General Maintenance and Repair 8 02-09-2011 03:31 AM
electric l/100km MJ/km Efried Fuelly Web Support and Community News 2 08-25-2008 08:41 AM
Beating the Baro... MAP reading trickery? GasSavers_RoadWarrior General Fuel Topics 4 03-06-2008 02:43 AM
Suggestions/Help/Curious? 96744 General Fuel Topics 6 08-24-2007 09:20 AM
Newby here diaperden General Fuel Topics 4 06-19-2007 01:54 PM
