Tire inflation - Fuelly Forums
Old 03-14-2010, 04:32 PM   #1
Tire inflation
Hello. I drive an 85 Ford Ranger and I was wondering what would be the recommended amount to inflate my tires to? I have them at 44 right now, but want to most fuel economy from them. Any suggestions?
Bigdtown is offline   Reply With Quote
Old 03-14-2010, 04:54 PM   #2
What is the maximum pressure stated on the sidewall of your tires?
Old 03-14-2010, 05:01 PM   #3
44 psi(?)
Old 03-14-2010, 05:11 PM   #4
Banned
for safety I prefer on my fwd car less air in the front steering tires and more in the back non steering tires, thats me though
31-32 front
34-38 back
rwd is different though
Old 03-14-2010, 05:26 PM   #5
In my 3000 pound VW with 195/65-15 tires, 51psi provides crisp, sure handling with decent ride. Your Ranger probably weighs about the same, if it's a 2WD 5 speed 4 cylinder regular cab. Your tires are probably 205/70-15, I'm guessing? If so, 44 would probably be about perfect, if the ride and handling are ok. You may need less in the rear.
I bet your tires are rated for a maximum of 44 and you should not exceed that anyway.
My full size pickup wears E-rated tires, good for 80psi. I can run 80 in the front but not much more than 70 in the rear.
Comfort doesn't suffer from my increased inflation in any of my vehicles. Handling, durability, and wear are significantly improved for me in addition to fuel savings. YMMV.
Old 03-14-2010, 05:31 PM   #6
If you're already running the tires at the max sidewall pressure, its not recommended that you put that much more in them. That being said, the sidewall pressure for my Buick's tires is 35, but the tires wear even at 40 so that's where I keep them. That's the most important thing. If you cause abnormal wear, and have to prematurely replace your tires, any fuel savings you get will be more than made up for with increased tire replacements.
Old 03-14-2010, 05:55 PM   #7
OK, thanks for the info everyone!
Old 03-14-2010, 06:00 PM   #8
Banned
agreed, had 38psi on the same depth tread on my back wheels for like 30k
'95 Honda Civic DX hatchback w/ VX tranny pinging cems70 General Maintenance and Repair 8 02-09-2011 03:31 AM
Which Wheel To ReTire bowtieguy General Maintenance and Repair 4 04-16-2008 07:41 AM
Beating the Baro... MAP reading trickery? GasSavers_RoadWarrior General Fuel Topics 4 03-06-2008 02:43 AM
Performance Underdrive Pulleys? cfg83 General Maintenance and Repair 10 09-08-2007 09:04 PM
Newby here diaperden General Fuel Topics 4 06-19-2007 01:54 PM
