Timing belt/water pump replacement - Fuelly Forums
Old 07-24-2007, 07:17 AM   #1
Rick Rae's Avatar
It's time to have the Cabrio's timing belt and water pump replaced. Just thought I'd ask if I'm missing any opportunities for FE improvement here (e.g. a higher-efficiency pump, change to electric, low friction timing belt etc.)
Thanks for any insights,
Rick
Rick Rae is offline   Reply With Quote
Old 07-24-2007, 07:44 AM   #2
I think that changing to electric would help FE. And power, really. Spinning that thing 6000 rpms when you wind 'er out has to take quite a bit of power.
Hey, wait a minute. I don't know how many people know this, but restricting the outlet on a centrifugal pump will generally reduce the amount of power it draws (which I know is counterintuitive). So if one could restrict the water pump outlet, one could reduce the amount of drag the pump causes.
But you would want for it to be controllable in case you REALLY DID pull a 5000 pound trailer 100 mph up a hill on a 110 degree day...
Anyway, something for one of the genuises here to figure out - an easy, adjustable way to restrict the outlet of the water pump...
Someone with experience with pumps come to bat for me here too - centrifugal pumps draw less current or use less power when the outlet is restricted, right? I know someone is going to try to smack me around for suggesting such a thing.
Old 07-24-2007, 07:51 AM   #3
Send a message via AIM to Raccoonjoe Send a message via MSN to Raccoonjoe Send a message via Yahoo to Raccoonjoe
I've heard about the electric water pumps, but have shied away from them for now. Too expensive, not enough testing done for the Jeep applications. Also, on the Jeep.....the water pump sits up against #1 cylinder. water pump grenades = holes in cylinder wall. Don't laugh too hard.....I've seen it done.
Raccoonjoe is offline   Reply With Quote
Old 07-24-2007, 08:20 AM   #4
I think I would put the pump somewhere away from the block for reasons like that. Since it's electric, I could put it wherever I wanted.
Old 07-24-2007, 08:32 AM   #5
but then you have the electricity to run the pump coming from where? the alternater which is driven by the belt...a replacement pump is usually under $50 while im guessing an electric one is more. have any of you spinned the water pump pulley with the belt off? theres very little rersistance... same with the power steering pump
Old 07-24-2007, 08:52 AM   #6
Yeah, it would use electricity from the alternator, but it would pump the right amount of water, instead of 6 times what you really need, so it would save that way. It's the same idea as the electric cooling fans, really. It would run at "low" speed most of the time, and kick up to "high" if it needed to.
Old 07-24-2007, 09:12 AM   #7
GasSavers_Red's Avatar
Find a wrecked new BMW 3 series, I'm pretty sure they have atleast the electric water pump part down, maybe the variable nozzle as well.
Old 07-24-2007, 10:00 AM   #8
Rick Rae's Avatar
I agree, it should help. On the other hand:
1) A mechanical pump is a direct mechanical-to-mechanical drive. With an electric pump, you're converting from mechanical to electrical (via the alternator/battery) and then from electrical back to mechanical (via the electric water pump). The losses in both conversions will limit the possible gain.
2) I imagine most hypermilers run lower revs in general, so the gains from "as needed' pumping may be less for us than for the typical lead-foot.
Plus I read someone's test where they completely removed the drive belt(s) -- taking out the alternator, A/C compressor, etc. (not sure if the water pump was on that list) -- and only reclaimed about 3HP.
I have no doubt that an electric water pump would help. How much it would help is an interesting question, though.
On the third hand you're talking exactly the same parameters for electric fans versus mechanical drive, and haven't we determined that offers a usable improvement? I would think a water pump conversion would be similar.
Unrelated to FE but still an issue: If the water pump is driven by the timing belt, then if one switched to an electric pump, wouldn't they need either an idler to take the place of the mechanical pump, or a different (shorter) timing belt (if such a beast even exists)?
I'm not trying to be argumentative here -- just tossing in some reasons why the switch to an electric water pump may not offer the level of benefit we might like.
Now, someone show me I'm wrong and we're actually talking about a 10%-15% gain potential here so I can get one ordered.
Rick
Old 07-24-2007, 10:14 AM   #9
Yeah, no, you're not being argumentative. I'm not sure how much hp a car's water pump draws. One hp? A 1-hp pump will move a ton of water. But, then again, if you can reduce your power demand by 1 hp, you would bump your mileage at least 5%.
With it being under the timing belt, I think it goes beyond the level of complexity that I would want to attempt.
If you did go to electric, you could do other cool stuff like reverse the flow so that "cool" water goes to the head first. Oooo, and have a Prius thermos thingy...
Really, I was just thinking out loud and hoping to give you something to go on so that YOU could generate the actual good ideas. :-)
Old 07-24-2007, 11:46 AM   #10
Send a message via Yahoo to GasSavers_BMac
Yea, advance that cam!
1998 Dodge Dakota Sport 5.2 auto,
Aero Cap,
Cam advanced 4 degrees,
MSD 6TN,
MSD Blaster2 Coil,
MSD 8.5mm SuperConductor wires,
Borg-Warner cap & button
Halo plugs,
PCV jar
and more to come...
GasSavers_BMac is offline   Reply With Quote
Low cost AC drive motor / homebuilt hybrid retrofit usedgeo Hybrid Vehicles 23 02-07-2012 12:54 AM
Fuel Heaters GasSavers_Red General Fuel Topics 31 12-14-2006 11:13 AM
Cardboard box + duct tape = LxMike Aerodynamics 18 11-18-2006 10:53 AM
BMW C.L.E.V.E.R. Concept MetroMPG General Fuel Topics 4 04-24-2006 10:59 PM
