Personally, I don't know about the throttle versus rpm debate, but it seems that darin has made the switch from minimal throttle pressure to moderate with no hit in gas mileage, and as mira has said, the real issue is what you do to lose that speed once you have gained it, not so much how you get there. I generally practice low throttle because it's easier for me to do consistently, but I often do the moderate throttle thing when the benefits are obvious.
