Originally Posted by Compaq888
Your car is an ex, which has a totally different tranny and IM. Which changes everything. What's good for your car might be bad for mine.
The 1, 4 and 5 gears are identical in our cars. My 2 and 3 are a little shorter/closer to give a little more sporty acceleration.
So basically you're accelerating with a lot of throttle but shifting extremely low? I guess Ill try that; if anything it wouldnt piss off as many people behind me compared to now
Right now Im shifting at 2500 in all gears, unless Im cruising at 35-45, then I just put it into 5th. I tried the same style SVOboy used in his post, but I ended up getting worse mpg than I got before I even came to this site and learned some techniques and tricks etc. God I wish I could afford a scangauge.
