thermostat issues - Fuelly Forums
Old 03-01-2011, 11:28 AM   #1
vxdude's Avatar
Send a message via Yahoo to vxdude
thermostat issues
Guys, just replaced my radiator and thermostat, but now sometimes my VX takes 10-15 minutes to warm up on cold mornings. Is there any other culprit that might be causing this besides the thermostat?
Thanks!!!
vxdude is offline   Reply With Quote
Old 03-01-2011, 11:54 AM   #2
benfrogg's Avatar
Re: thermostat issues
Hose routing? I know the vx has that funky routing; the lower outlet on the radiator feeds the thermostat housing and the upper outlet feeds the front of the block, etc.
Otherwise, make sure it's the right tstat, etc. It could be a failed tstat from the factory, although that would be rare. Did you use a gasket around the new tstat?
B
Old 03-01-2011, 12:48 PM   #3
vxdude's Avatar
yep i used a new gasket and the thermostat is 180,
Old 03-01-2011, 02:04 PM   #4
hmm well as you know most tstats nowadays are made in india, thier quality control is crappy. to test to see if its functionign correctly take it outa the car and dangle it touching a pot of water on the stove. turn on said stove with a termometer in it and see when it pops open. my guess it aint gonna be 180 as my expereince 1/2 are bad from the start
Old 03-01-2011, 09:33 PM   #5
vxdude's Avatar
will do, i should have done that before i put it in
suggestion: running averages of data? roadent Fuelly Web Support and Community News 4 10-27-2008 10:58 AM
Stations that sell E10 (read: Stations to avoid) GasSavers_DaX General Fuel Topics 46 01-10-2008 04:46 AM
new to the site ranger387 Introduce Yourself - New member Welcome 5 11-12-2007 07:17 PM
another new guy jbrando Introduce Yourself - New member Welcome 4 07-10-2007 09:51 PM
Gaslog suggestion SVOboy General Discussion (Off-Topic) 1 04-29-2006 09:35 AM
