Thermoelectric generator - Fuelly Forums
Old 03-07-2006, 06:41 PM   #1
GasSavers_nathan's Avatar
Does anyone on here know anything about thermoelectric modules?
I saw them in a fan which is used to circulate heat from woodstoves.
It uses heat from the stove to generate electricity which runs the fan motor.http://www.modernoutpost.com/gear/de...cf_ecofan.html
If you had enough of those attached to the engine youd be able to get rid of your alternator, and I'd imagine it would aid in engine cooling as well.
I came across a site that offers thermoelectric generators http://www.hi-z.com/but I dont know too much about electronics so I dont really know if it would work.
The cost of them may make it too expensive to be worthwhile.
GasSavers_nathan is offline   Reply With Quote
Old 03-08-2006, 07:13 AM   #2
TE modules
I saw that website a while ago. If you dig into their site, you can find that they built a prototype 1 kw (80 amp)thermoelectric generator for diesel trucks. It will save gas, but the costs of those TE modules is simply ridiculous!
Old 03-10-2006, 04:29 AM   #3
thermal junctions
They are a junction of two different metals and when heated give off a very small electrical current - there also has to be a second matching junction that is cool. Takes a pile of them to produce any amount of voltage - a thermal pile that is.
Old 03-10-2006, 08:33 AM   #4
Moderator
GasSavers_DaX's Avatar
Re: thermal junctions
Thermocouple anyone? What I think is interesting is how you are able to use them in reverse - applying a current to a thermocouple can be used as a regrigeration device.
Old 03-11-2006, 07:39 PM   #5
humm not sure
Humm not sure about that - there are Peliter Junctions - I have a few that are really cool. One is not mounted on a heat sink - just the ceramic material with two leads and if I connect a single AA cell to it - one side gets hot and the other side gets cool - about 2 inches square and 1/8 thick.
Old 03-24-2006, 06:29 PM   #6
GasSavers_Ryland's Avatar
some number crunching.
I was just about to post a new topic with the same title, and realized I should look back to see if I was being redundent...
according to my figures, a thermo electric generator from Hi-Z would cost around $8 per watt of generator, Solar (PV panals) cost around $4.50-$5 per watt, just as a comparison (but PV needs sunlight).
And I'm not sure on the life span of Thermo generators, altho they are a solid state generator, they are also subjected to alot of heat, and need cooling, so that puts alot of stress on them I would think.
I just sent an Emial to Hi-Z asking them about passenger car sized units, I'll see if I get a response.
How much energy can you get out of your exaust? those generators seem to peek out at 5% efficentcy, but your gas engine peeks at around 27%, and figur that maybe half that wasted energy is going out the tail pipe in the form of heat, and presher? so to make it simple, you have as much energy going out your tail pipe, and out your radiator, each, as your car produces (please, someone correct me if I'm way way off base here) but lets say my 92hp civic vx engine produces... on average 40hp while I'm driving around town, 5% recaburing efficenty of 40hp is 2hp of energy that could be capured in the form of electricity, something like 750 watts per horse power, so, if you were to recapture all of the heat going out your tail pipe, in theory you could get 1,500 watts of electricity... and you would have cold exaust of course, now you can not capure 100% of that heat, but then you also don't need 1,500 watts, sure your starter is around 1,200 watts, but it only runs for 3 seconds, your headlights are 65 watts each, you might have 6 indicator lights at 5 watts each, and 10 more at 1.5 watts, brake lights 25 watts each, of course other then headlights you can replace all your lights with LED's (head lights will be coming soon I'm sure) and cut 45-50 watts of that down to aorund 3-5 watts but then you have the ignition coil, fuel pump, radio, computer, so let say between 250, and 300 watts, will alow you to keep driving at night listening to the radio as long as you don't have a sub woofer.
so to get a thermo electric generator that would produce just that 300 watts it's going to cost around $2,500, you of course could suplement that a little with some PV to keep your battery charge in the day time sun, and that might be a good idea anyway as this kind of system wouldn't produce power for the first minute or so of the car running.
so I think you would be able to make something that would be able to compleatly replace your alternator and keep up with most reasonable electrical loads, however it's going to cost alot, more then I paid for my car I know for sure, and I still think it's a good idea, and I keep checking to see if the price has gone down, and it hasn't in the last 4 years.
Old 04-26-2006, 06:27 AM   #7
I just got an Email back
I just got an Email back from Hi-Z, it reads as fallows:
"We are working with Clarkson University and NYSERDA (New York Sate
Energy Research and Development Agency) to develop a 300 W
thermoelectric generator. It is designed to go on a GMC Sierra pickup
truck.
I have attached a copy of the presentation we gave at a conference in
Detroit.
It will probably be several years before such a generator is available
to the general public. Because of lack of funding, the development
seems to be going very slowly.
Sincerely,
John C. Bass
Vice President
Hi-Z Technology Inc."
I'll try to figure out how to put the PDF file on my web page, and link to it on here.
--Ryland
Old 09-19-2010, 09:23 PM   #8
Re: Thermoelectric generator
These are really good!
Solarhersteller is offline   Reply With Quote
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 11:17 PM
Road and Track story on saving Fuel VWJunky General Fuel Topics 3 11-20-2008 03:44 AM
Reporting capabilities via SMS? hidesertmlb Fuelly Web Support and Community News 4 09-02-2008 01:02 AM
The Mechanic was like, "WTF?" rh77 General Fuel Topics 15 02-14-2006 04:15 PM
Gassavers Dictionary of Technical Terminology krousdb General Discussion (Off-Topic) 7 02-11-2006 06:30 PM
