The case for motorcycles. Why not use one? - Fuelly Forums
Old 12-13-2007, 02:49 PM   #33
Mighty Mira's Avatar
the problem is the dustbin moves the center of pressure forward to the point where a good xwind will blow it off the road. seriously.
I'm not saying the dustbin (as in the Cx) is the best way to design a fairing. As you can see from my designs, the center of pressure would be hardly moved. Although most likely not necessary, you could fair a bit more of the back to make up.
I strongly suspect that there are three main things you can do on a motorcycle to reduce drag.
1. Enclose wheels, because these get air rotating around with them, effectively having much larger area than they do. This couldn't get worse than with a bike, where the wheels are totally exposed (but don't have to be).
2. Smooth the airflow at the front, like a bullet. This gets the air flowing to the maximal area with as little resistance as possible. After this there is a wake, which you can either hide stuff in (like a rider and the rest of the motorcycle), or eliminate via a smooth, gradual taper.
3. Reduce the pressure drag at the back via said taper.
A dustbin fairing has no substantial taper back, and contributes a reasonable amount of side area. I suspect that 90% of the job it does could be done by fairing the front wheel and the handlebar to top of driver region, in something with relatively small side area.
well, yes there is. bikes are light. conventional bikes don't enjoy as big a break on frontal area as you'd think vs cars. and of course the Cd sux. unless you get radical with enclosed or nearly enclosed fairings.
Well, let have a look, shall we? Figures of around 0.56 square metres are bandied around for the hayabusa. So lets say that a more upright bike like the Honda CT110 has something like a frontal area of 0.8m^2. My Mira has a frontal area of 1.79m^2, and that is very small for a car. Which is less than half of mine. Something in a sport bike or recumbent style would be in fact less than 1/3.
Now, the initial drag coefficient is close to 1. A flat plate would be just as bad. I suspect that properly fairing the wheels and doing what I did in my Gimped version of the postie bike, you'd get it down to at least 0.5. At that stage, the CdA would be a bit less than my car. Maybe more, because not many people understand why unenclosed, rolling wheels are so bad for drag.
Going further, what you describe as radically faired need not be impractical. It's more a matter of fashion. And fashion is fickle - back a few hundred years ago the height of fashion was the codpiece. What "people won't do" is not constant.
The practical HPV I linked to earlier seems to indeed be practical.
So quantifiably, coast time is proportional to m/CdA.v^2.
Ignoring velocity, my m/CdA = 765/.46=1675 kg/m^2
Typical postie bike = 200/(.9* .8) = 277 kg/m^2, so coast time would be 16% of my car.
Modified with front shield and wheel fairings, I'm estimating 0.5 for Cd. So m/CdA = 500, or 30% of my coast down time.
I'm estimating 0.2 for the Cd of a practical HPV style modified postie bike.
m/CdA = 200/.8/.2 = 1250, or 75% the length of my coasts. Which is close enough not to worry about. Recumbent or sport bike style would probably beat my coast down times. Remember that there are many people here who are P&Ging with m/CdA worse than my car.
The other thing to consider is velocity. A 10 kph coast down in my car is about 8.5 seconds at 100kph. I happily do that. The modified postie bike would have a 10kph coastdown time of 8.5 seconds at about 55kph. I do a lot of my driving at 60kph or less, so this would certainly be worthwhile doing from my perspective.
I haven't ridden a motorcycle in a long time, but do they have a similar mechanism to a regular bike, where it automatically coasts if you do not provide peddle power? Is it easy to do?
"Really, without a fairing, there's not a lot of frontal area on a bike." You'd be surprised... especially when you stick the rider on it.
You are right, thanks for making me double check my figures, although I don't believe it is an insurmountable problem.
if posties are used the way i speculate they're used, they never get going fast enough for a fairing to matter anyway. then the fairing is just extra cost and weight and gets in the way of functionality.
Actually you'd be surprised. Remember that the force of rolling resistance is proportional to mass. Since mass is at LEAST a 1/4 of that of a normal car, drag takes over at a much smaller velocity. My calculations have it at about 18kph for the unmodified postie bike. That's tiny!
Mighty Mira is offline   Reply With Quote
Average running mileage on dashboard mistakely same as last fill-up. MatrixDom Fuelly Web Support and Community News 3 06-15-2011 02:21 AM
Car Filtering by Engine and Body Style pb Fuelly Web Support and Community News 5 10-16-2008 02:33 AM
MazdaSpeed3 HEK Car Reviews 4 07-12-2007 07:28 AM
Hypermiler? jdham137 Hypermiling 13 06-13-2007 05:55 AM
partial boat-tail MetroMPG Aerodynamics 34 09-10-2006 05:43 PM
