Temperature of air in my intake - Page 2 - Fuelly Forums
Old 05-12-2006, 10:48 AM   #11
kickflipjr's Avatar
Quote:i am going to see if i
i am going to see if i can raise up the temps some more with alluminum foil and other insulation stuff (it won't look pretty).
I went on a fairly short drive and was around 150F today. It looks like the aluminum foil works. Ambient air was 60F today.
2008 EPA adjusted:
Old 05-12-2006, 12:45 PM   #12
Re: I can't believe how much my
Originally Posted by Randy
I can't believe how much my car hates warm air. A couple weeks back I tried a little warmer air by flipping around the Civic snorkel thing so it sucks air from behind the radiator instead of behind the headlight. I have about half the radiator blocked (guage reads exactly the same as before), but the air can't be very hot.
Anyway, it worked fine during cold weather, but when it gets over 70 it'll ping like crazy at high throttle settings. Doesn't matter the RPM. I flipped it back and it works fine again. This is a dead stock D16z6, and I checked the timing not long ago. I'm glad I tried the free/simple path before something more elaborate.
I had the same problem, so I just went up an octane level in the Winter, and then use Premium in the warmer months. The cost-benefit ratio may vary, but it's worth it for me. I max out at 160F, and I had pinging at around 110-120F, so I'm guessing that's where you were at.
Old 05-12-2006, 01:23 PM   #13
Re: Quote:i am going to see if i
You need to make sure it doesn't get hotter than about 200f when it gets to the throttle body or you'll find the engine running rough and retarding spark
cheapybob is offline   Reply With Quote
Best Diesel in N. Texas? JudisJetta General Fuel Topics 7 05-28-2010 08:55 AM
Need way to indicate a missed fuel-up entry exists silente Fuelly Web Support and Community News 7 08-20-2008 07:46 AM
