Just got back from surfing for info on Xcelplus and Teflon related additives. Checked out the Xcelplus web site and WAS SOLD! (not really, had to check a few more sources 1st). Found an archived article and wanted to share some of what was written...
Make your own conclusions, but I don't know if I want to chance an expensive oiling concern. It's a shame, I guess I STILL want to believe in an additive that will do what is claimed.
If anyone has heard/read/experienced any other info in regards to this please post. Thanks
[quote]…”The problem with putting PTFE in your oil, as explained to us by several industry experts, is that PTFE is a solid. The additive makers claim this solid "coats" the moving parts in an engine (though that is far from being scientifically proven). Slick 50 is currently both the most aggressive advertiser and the most popular seller, with claims of over 14 million treatments sold. However, such solids seem even more inclined to coat non-moving parts, like oil passages and filters. After all, if it can build up under the pressures and friction exerted on a cylinder wall, then it stands to reason it should build up even better in places with low pressures and virtually no friction.
This conclusion seems to be borne out by tests on oil additives containing PTFE conducted by the NASA Lewis Research Center, which said in their report, "In the types of bearing surface contact we have looked at, we have seen no benefit. In some cases we have seen detrimental effect. The solids in the oil tend to accumulate at inlets and act as a dam, which simply blocks the oil from entering. Instead of helping, it is actually depriving parts of lubricant."
