Originally Posted by cfg83
j
Warning : For some gas tanks (may or may not be true for you), the gas is used as a lubricant (for the fuel pump?), so you shouldn't run the tank dry. I think 1/8 tank is a good rule unless your gas stations are few and far between.
There is that and the fuel pump sucking in all the gunk that has settled at the bottom of the tank. If you have a vehicle with a serviceable fuel filter its probably not that big of a deal, but those with so called "life time" fuel filters, the filter media isn't as adept at filtering junk. Atleast this is so on my TJ.
