Taller gears! - Fuelly Forums
Old 01-11-2010, 11:32 AM   #1
fowljesse's Avatar
Taller gears!
I am going to get a transmission from a Mazda 626 with taller final gears (4.111:1 instead of my 4.388:1), and it has a taller 5th, so I will lower my 65mph rpm by a little over 400. With that, and running lean, I should be able to get into the 40mpg range!
I imagine that most people can find taller junkyard gears for their cars. I know it's not a DIY thing, unless you have the time, and tools, but it can make a big difference. I have to change my clutch anyway, so I'm doing it all at once. The standard mileage for this car is 28HWY with a 1.8L, and this one has a 2.5L.
fowljesse is offline   Reply With Quote
Old 01-13-2010, 07:33 AM   #2
That's a lot of rpm change for such a small gear change! 3.55 to 3.92 only changes my 65mph rpm by 200 rpm.
What are you normally turning on the freeway? What is the overdrive ratio?
- Kyle
Old 01-13-2010, 04:21 PM   #3
fowljesse's Avatar
The "and it has a taller 5th" part is hiding after the ratios . I don't remember what the ratio was for 5th, though. It's a bit of a jump from 4th to 5th, but with variable resonance induction, the engine has a good long torque curve. The gearing was made small with this car for "more fun", so 60mph is about 3,100 rpm. For the first 6 months of driving an MX-3 GS people try to change out of 5th on the freeway, and remember that that's it.
There's a guy that's figuring out a way to mate a G6 6 speed tranny to this engine. That would be awesome.
Old 01-26-2010, 06:23 PM   #4
kamesama980's Avatar
when you've got high rpms to start with, small gear changes make a big difference.
-Russell
Partial Fuel-up Calculations Improvements ryogajyc Fuelly Web Support and Community News 16 04-17-2012 09:25 AM
FE Observation aalb1 General Fuel Topics 9 01-10-2009 03:22 PM
92 Civic 1.5 engine work with CRX? UfoTofU General Fuel Topics 4 10-08-2006 06:50 PM
Cool Java App For Calculating Power Needed at Given Speed Mighty Mira General Fuel Topics 0 06-26-2006 08:14 PM
Dan: Pimping for the del sol SVOboy General Discussion (Off-Topic) 8 04-08-2006 05:12 PM
