Originally Posted by VetteOwner
heh after 3K mines a very dark brown, almost black. but it turns colors within prolly 500 miles i notice it getting darker...
Yes, oils change color VERY quickly, and that's really not much of an indicator of how "bad" it is, unless it's a DRASTIC change in color and viscosity.
When I switched to Synth, I noticed a nice gain in fuel economy, so I keep on keeping on.
Recently, I began to use Liqui-Moly MoS2; it's a liquefied Molybdenum disulfide. They usually add small quantities of this to most oils in case of catastrophic oil failure. The MoS2 bonds to the metal and prevents outright Metal-on-Metal contact.
I put a can of that in my car the last oil change, and it noticeably smoothed out. It's very nice...and only like $7 for a thing of it.
In Germany, one can buy Liqui-moly oil, which is a premium Synthetic with the MoS2 already suspended in it. Here, I've never found anyone who imports it
BUT, I found the MoS2!
http://www.germanautoparts.com/chemi...s/Lubro-Moly#1
I usually use this with Royal Purple.
My brother uses this with ELF oil.
IIRC, Mobil 1 recently dropped a grade of synthetic to where now it is highly refined conventional or it uses lots of wax as a base...I don't remember how bad it dropped, but it's definitely on the low end of the scale.
Royal Purple is fairly up on the scale...I remember Castrol is about Central, EXCEPT there is a high-viscosity German-made Castrol (has a green background) which is a higher grade synthetic.
ELF is a crazy high one, as is Liqui-moly.
My brother said he actually found someone who's importing Liqui-moly, so he wants to try that next time.
I should also mention, ELF is a racing oil. So, my brother's interest is less to do with fuel economy and more to do with a crazy-high performance oil for his tuned Golf. So, as nice as ELF and Liqui-moly are, their premium price is ridiculous...I have no need to use them, and I really don't think anyone here does either. They shine mostly in that they have a very high threshold of thermal breakdown...which is good for PERFORMANCE engines...I doubt any of us are holding our engines WOT at any point, let alone for several minutes at a time...
Just my 2?
