Supermid-Swift Help (VSS) - Fuelly Forums
Old 11-05-2007, 09:29 PM   #1
cwa
I got the Supermid from Yoshi last week. I was managed to fix it with correct VSS and Injector signal (which was found by Yoshi sometimes back).
However it looks like that VSS signal is not properly detected by the Supermid unit. (No signal at all). Therefore only Injector pulse width and the total fuel usage is recordered.
Is anyone who installed Supermid give me some advice?
Regards
CWA
cwa is offline   Reply With Quote
Old 11-05-2007, 09:30 PM   #2
ajohnmeyer's Avatar
Send a message via AIM to ajohnmeyer
what kind of car are you installing it on? which wire(s) are you using for the VSS signal?
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." -The Drive By Truckers
Team OPEC Busters!
ajohnmeyer is offline   Reply With Quote
Old 11-05-2007, 10:49 PM   #3
cwa
MY car is Suzuki Swift 2002-2204 Model (Japanese doemstic) with 1.3 / Auto.
I got the ECU diagram and tried on Both VSS and TP signal.
Regards
CWA
Old 11-06-2007, 03:37 AM   #4
skewbe's Avatar
FWIW, on my 98 metro the vss is the yellow and green wire going into the ECU.
Standard Disclaimer
Banner problem laserdough Fuelly Web Support and Community News 6 03-13-2012 09:21 AM
More lists? skinnious General Fuel Topics 4 12-07-2010 11:12 PM
$4000 Hybrid Option rh77 Hybrid Vehicles 3 05-03-2007 12:14 AM
Fort Wayne, IN man. Wyldesoul Introduce Yourself - New member Welcome 8 04-18-2007 03:22 PM
Poll: Should Stability Control be Standard rh77 General Fuel Topics 14 09-30-2006 09:44 PM
