supermid m-1 - Fuelly Forums
Old 05-24-2006, 01:52 PM   #1
supermid m-1
I'm new. I'm dumb. Now that we have that established, what is it, who makes it, where do I get one?
Kevin A Thornton
KAT Automotive
For Speed Equipment, Nitrous Express
katman@everestkc.net
For AMSOIL products
https://www.lubedealer.com/kat
For Herbs from the Amazon
https://www.168336.amazonherb.net
GasSavers_katman is offline   Reply With Quote
Old 05-24-2006, 03:57 PM   #2
krousdb's Avatar
It is a device that measures fuel consumption and distance traveled by sensing signals from your ECU. If you are OBD1 (pre 1996 in most cases) it might be the only device to help you measure fuel consumption. If you are OBDII (97 and later) you can also use the scangauge.
The SuperMID is not readily available, they are custom made by Yoshi. If you ask real nice he might make you one.
The scangauge is readily available. Just do a google search.
Old 05-24-2006, 04:10 PM   #3
Hi katman -
Welcome to the site.
Whichever meter you end up using, you won't regret shelling out the $. (Besides, if you use it regularly to fine tune your vehicle & driving, it'll pay for itself.)
Also, I suspect some of the 1st generation ScanGauges will be showing up on eBay now that v.2 is available.
Old 05-24-2006, 04:29 PM   #4
I was looking at becoming a dealer for the ScanGauge but they are still working out their dealer plan.
So do both do the same thing?
I have a 97 Tahoe 2dr, 5.7, auto, 4x4. AMSOIL in everything, 3oz/10gal of Acetone and zylene, and 1oz/10gal AMSOIL PI.
Been getting around 15 MPG +/-. Just took out the Bosch +4 and installed Halos. On my test hills I was able to just barely accelerate up hill. With the +4 I was barely able to maintain 55 MPH. But I don't have many miles on since the plug change and the computer is still adjusting.
Kevin A Thornton
KAT Automotive
For AMSOIL products
Old 05-24-2006, 04:43 PM   #5
tomauto's Avatar
Send a message via AIM to tomauto Send a message via MSN to tomauto Send a message via Yahoo to tomauto
odds
The odds are against you with that combination my friend. 15 mpg is nothing to call home about. If you can get that figure in the 20 mpg range you will be doing good. You can get a scangauge for your vehicle no problem.
Also, remember to take out any excess weight you have in the tahoe. Every pound counts
Current Stable
tomauto is offline   Reply With Quote
Old 05-24-2006, 04:51 PM   #6
krousdb's Avatar
So do both do the same thing?.
They both do the same thing but the M1 works on both OBDI and OBDII. The drawback of the M1 is that you cant plug it into the OBD port, you have to locate wires coming from the ECU and clip onto them. The M1 also is very compact but does not have an outer case.
Old 05-24-2006, 04:54 PM   #7
I bought a roll cage for my race car and blew up the engine so I never got a round to put it in. I also didn't have room for it in the garage so I kept it in the Tahoe for almost a year! It only weighs about 250 pounds! It's out now. I've got to pump the tires up to about 50 lbs and se if that helps.
Kevin A Thornton
KAT Automotive
For AMSOIL products
Old 05-24-2006, 04:55 PM   #8
tomauto's Avatar
Tire pressure
Make sure to check the max psi rating on those tires.
Current Stable
Old 05-24-2006, 06:35 PM   #9
Holy cow! That's more than 1/8th of my car's weight Taking that out= good move.
Old 05-25-2006, 01:10 PM   #10
Since you're 97 I think you should stick with the scangauge unless you plan on lots of engine off coasting or you wanna log some interesting information that the MID can accomodate.
Running on empty Axton General Fuel Topics 18 08-19-2013 05:32 PM
Banner problem laserdough Fuelly Web Support and Community News 6 03-13-2012 09:21 AM
Max cars reached. Texas Fuelly Web Support and Community News 3 03-11-2012 07:19 AM
More lists? skinnious General Fuel Topics 4 12-07-2010 11:12 PM
Aftermarket Cruise Control Mighty Mira General Fuel Topics 42 01-16-2010 05:03 PM
