Supermid Distance and Fuel Calibration Constants? - Fuelly Forums
Old 03-09-2008, 04:47 PM   #1
Anybody have any Supermid calibration numbers for CRX H? I just want to start with them close and calibrate over a full tank.
FritzR is offline   Reply With Quote
Old 03-10-2008, 08:51 PM   #2
guest001's Avatar
where the hell did you even get a supermid???
guest001 is offline   Reply With Quote
Old 03-11-2008, 07:40 AM   #3
Hi,
I would like to comment some...
It'll take long time to find the calibration numbers within 1% error on your CRX.
Please accumulate three tanks for the fuel usage adjustment.
The distance 2572 should be dead on if you wear a standard size of tires.
Anyway, the injector size on other CRX is different(more than 2%) from yours and tire diameter is also different, therefore the other CRX's calibration data is not always fitted to yours.
Yoshi
GasSavers_Yoshi is offline   Reply With Quote
Old 03-11-2008, 10:21 AM   #4
from Yoshi who posted above
Anyways I'm just going to calibrate it so 1 km/L = 2 mpg
"The distance 2572 should be dead on if you wear a standard size of tires."
My km reading is over by a factor of 1.39 so my vss signal must be off but I'll just fudge the number when I get a more accurate reading.
Thanks again Yoshi, nice product
Old 03-11-2008, 03:16 PM   #5
guest001's Avatar
???? I didn't know this this had to be calibrated so much. what if I'm running 4500cc injectors from a DSM.
Old 03-12-2008, 09:04 AM   #6
Oh, I see.
So, you're reading 1.39km when you drive real 1km, aren't you?
Maybe, your CRX has mechanical vss.
Thank YOU!
Anyway, a relative number is still good to compare your various technique for fuel efficiency. The absolute accuracy is not so important to compare them.
Yoshi
Old 03-12-2008, 09:11 AM   #7
If you need less than 1% accuracy, you have to do the calibration.
BTW, the 4500cc injectors are huge!
I've seen 550cc/min injectors, but...
Yoshi
Old 03-13-2008, 08:09 PM   #8
guest001's Avatar
^ the fuel maps are trimmed to compensate.
do you still sell these?
Old 03-14-2008, 02:18 PM   #9
you should PM him.
well I messed with my wiring and I guess I had a loose connection. Now the KMs seem to be on. I guess the vss wire was wiggling a little causing extra pulses
Old 03-16-2008, 10:21 PM   #10
Team GasMisers5!
landspeed's Avatar
I don't bother calibrating my SuperMID As it is the improvement in the number that counts anyway.
Be sure to write the numbers down, as, on the older SuperMIDs, the calibration didn't change ALL the numbers on the main display. This has probably been updated now, but is why I just keep the standard calibration!
Hypomiler
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 03:48 AM
Aftermarket Cruise Control Mighty Mira General Fuel Topics 42 01-16-2010 05:03 PM
Hello from Noobie owner of a 92 Civic VX dogncatboy Introduce Yourself - New member Welcome 29 10-12-2007 12:10 AM
