Summer mix fuel changeover - Fuelly Forums
Old 04-18-2008, 05:53 PM   #1
brucepick's Avatar
I think that CT must have changed over to summer mix fuel on Apr. 15.
My mpg has been hovering just under 27 mpg since early March. This afternoon I tanked up and it came out at a hair under 30 mpg. Yes the afternoons have been warmer but a solid 10 % increase nearly overnight? I think the fuel changeover has occurred, at least in this state. Likely much of the Northeast is on the same schedule.
If you're watching for this in your mpg results - remember that you need to fill with the new stuff first, then you could notice results at the next fillup after that.
Old 04-18-2008, 06:02 PM   #2
Not sure we've got it here yet, still smells wintery (Higher aromatic content, pungent enxhaust fumes etc)
Old 04-18-2008, 06:08 PM   #3
Hateful's Avatar
Send a message via AIM to Hateful
My mileage has gotten better recently but I thought it was just the warmer weather. The station I go to is always busy,so when it does change it should cycle out quickly.
Hateful is offline   Reply With Quote
Old 04-18-2008, 06:23 PM   #4
Come to think of it, I might be on summer gas since I filled up this morning. I was having hard starting issues when the engine was hot the last couple of days, but it started up better today, despite being hotter.
Old 04-19-2008, 06:33 PM   #5
I am experiencing a slight improvement in fuel economy too, even with the AC operating occasionally. Summer mix is good!
swng is offline   Reply With Quote
Old 04-19-2008, 07:47 PM   #6
I thought the last tank was my good driving!
Old 04-20-2008, 07:06 AM   #7
GasSavers_maxc's Avatar
If you have fuel injection, in opinion, your engine should run better on winter fuel.
I'm running 3 month old gas right now. Had some stored with alittle stabliser. No heat soak starting problems.
Sometimes I notice after top the tank off. Restart heat soaked engine throttle responce is very good and lite. Probability because the charcoal canister is giveing the engine a good vaper shot.
I have a 50F offset on my CTS. No cold start problems.
It would an interesing test to see the effects of heat on summer/winter fuel at different temps and pressures. Observe fuel in a clear tube in "realtime".
less lurking and more working
Old 04-22-2008, 08:22 PM   #8
Danronian's Avatar
My MPG went up about 3 or 4 for my last fillup. My car idles a lot lower when it's warm out, so I do think that had a lot to do with it since it has been a lot warmer lately. But who knows!
Old 04-23-2008, 07:02 AM   #9
My last couple of tanks have been impressively higher and I'm on task to get even higher with this tank. I loves me some summer blend gas.
Think inside the Box!
Improbcat is offline   Reply With Quote
Old 04-23-2008, 05:51 PM   #10
With a few mods it would be better to run winter gas in summer. If you had a place to store it.
Find friends disappears after adding a friend tggbenz06 Fuelly Web Support and Community News 2 08-30-2008 05:14 AM
hi new member here and ive got some sick ideas! csrmel Introduce Yourself - New member Welcome 6 10-18-2007 02:23 PM
