straight gas vs. 10% ethanol blend - Page 4 - Fuelly Forums
Old 01-10-2014, 06:49 PM   #31
You're right at the break even point, and when you consider your time for pulling over sooner and buying fuel again... not worth it.
Old 01-10-2014, 07:36 PM   #32
Unless it is a station you go past anyway, and/or they just top off once a week not matter what.
It comes down to priorities. Such as, is buying a domestic made fuel more important than having to fill up a day sooner.
Old 01-18-2014, 07:53 AM   #33
JBW
i get 1.5 more mpg using non-ethanol blend fuel.
JBW is offline   Reply With Quote
Old 01-18-2014, 08:36 AM   #34
What type of vehicle?
Old 03-04-2014, 10:17 PM   #35
The "ethanol in gasoline" industry uses more oil than it saves. Ethanol needs high compression (16:1) ratio engines to extract its energy efficiently. Ethanol used, but not burned properly, in low compression(9:1 to 11:1) ratio gasoline engines, inefficiently releases energy. Along with poor burning quality in gasoline engines, ethanol doesn't lower emissions, as when ethanol is used in high compression ratio ethanol engines. Gasoline vehicles, having as many as 100,000 miles, while burning modern refined 100%(ethanol-free) gasoline, have received commendations for low emissions.
litesong is offline   Reply With Quote
Old 03-04-2014, 10:29 PM   #36
Originally Posted by JBW View Post
.....non-ethanol blend fuel.
All ratios of ethanol blended into gasoline ARE blends. 100%(ethanol-free) gasoline is by definition, NOT an ethanol blend fuel.
PLUS, ethanol used(but not burned properly) in gasoline, can NOT be considered a FUEL, due to its inefficiency.
Old 03-05-2014, 07:07 AM   #37
The 'oil'/energy used for ethanol production varies by the accounting method and the feedstock. Some are negative and some are positive. The balance is getting better. Not using corn for the feedstock would be a positive step. Growing less corn in general would be a positive. It is a resource intensive crop that is mostly used to fatten up factory farmed livestock that we all should be eating less of anyway.
Gasoline production is becoming a more energy intensive process. Canadian tar sands, which is supply gasoline to a large portion of the US, takes about 3 times as much energy as Texan light, sweet crude to get out of the ground and refine. That will only get worse as time goes by.
Flex-fuel engines should have been based on premium gas fueled ones, or, better yet, designed for E85 and adjust down for gasoline. The ethanol in E10 only raises the octane of the blend by around 2. Not enough to run the engine at a higher compression ratio to benefit much. Considering Americans are pennywise and pound foolish when it comes to gas octanes, using a higher compression ratio would be a tough sell. People decry cars with premium 'recommended'.
Ethanol has many flaws as a fuel, and methanol from natural gas or bio-butanol would make a better fuel. Ethanol does have some pros. It is a far better choice than MTBE. Though we only need about 5% for that. Compared to gasoline, methanol, and butanol, it is non-toxic and quickly breaks down in the environment in the event of a spill. Domestic made fuels are better for the economy. Going back to 100% gasoline means more money to terrorist supporting nations.
Ethanol isn't my first choice. It has flaws, and was chosen more by politics. lobbyists in general suck.
Old 03-09-2014, 10:42 PM   #38
Smile Ethanol Free Gains MPG
When I did get pure gasoline a few times in my Elantra, I saw a strong 10% increase in fuel economy PLUS the responsiveness was better overall.
Ethanol is a taker, not a giver!
driver57 is offline   Reply With Quote
Old 03-19-2014, 10:44 AM   #39
Well, now, this really sheds a different light on the whole E-10 versus pure gasoline (ethanol free) business. Seems that a lot of the CountryMark stations are now selling the pure gasoline in their stations. I guess the best idea would be to run a tank of E-10 until gone, then run a tank of ethanol free. And if it is really high priced, I can't see the return on investment.
Janstheman is offline   Reply With Quote
Old 03-19-2014, 01:21 PM   #40
The station I usually buy my fuel from only charges $0.10/gal more for ethanol free, and under that circumstance, its actually cheaper to run E0 than E10 because of the increased mileage I get on E0.
Matching EPA Type to My Car DastardlyDan Fuelly Web Support and Community News 2 10-26-2009 07:16 AM
Florida announces first commercial cellulosic ethanol plant theholycow Automotive News, Articles and Products 3 03-01-2009 02:01 PM
searching? blind monkey General Discussion (Off-Topic) 7 01-09-2009 07:16 PM
Why did it take me so long to find this place? Baranfin Introduce Yourself - New member Welcome 6 05-31-2008 05:17 PM
Hello, tracking my '96 Saturn for MPG! Project84 Introduce Yourself - New member Welcome 7 12-27-2007 10:00 AM
