Standings and Stats: Beginning May 21 - Page 44 - Fuelly Forums
Closed Thread
Old 07-01-2007, 07:35 AM   #431
XFi
XFi's Avatar
Just repaired the Xtiva's 'no spark concern' (Distributer-Crank Position Sensor). Replaced the distrubuter with one from an extra engine I have. Not going to be able to fit in another fill. But up and running for the next cycle.
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline
Old 07-01-2007, 04:26 PM   #432
...and the saga continues
Speaking of the next Cycle, beginning Monday, July 2, 2007 -- Cycle 3 begins!
BTW, Happy Canada Day -- which happens to be the last day of this cycle's competition. Make sure the GasLogs are up-to-date, since that's where the data is sourced for the final tally. Midnight Central Time is the requested deadline.
Bear in mind -- it's a seamless transition into Cycle 3, so keep that FE up
In the meantime, I'll crunch the numbers, have it double-checked, and post the results this week. It should be close!
Also, I'll be on vacation for a week or so (starting Friday) -- so if there are any issues, Zpiloto should be available to answer questions. If a timestamp is required for the issue, just cc me on the PM, and I'll get to it when I get back. Not sure what kind of Internet I'll have access to in Alaska
Best of FE to all teams!
The Commish
P.S. As of tomorrow, this thread will be closed to make room for the Cycle 3 update thread.
rh77 is offline
Old 07-01-2007, 08:33 PM   #433
CO ZX2's Avatar
Fill update 7/1/07.
330.6 miles, 3.24 gallons, 102.3 mpg, SG 37 tank mph.
I've been on strike since gas prices went over $3.50. Started my trips before 6 A.M. to avoid the winds that come by 7:30. Also lighter traffic. Still chilly mornings so I drive with my engine compartment insulation in the morning and remove for my return in the warmer afternoons. Alternator switched off all trips. Have left a battery at my shop to switch there instead of carrying a spare. Also disconnect my knock sensor on returns, more timing for uphill pulls. I have also slowed down some on my uphill returns.
I use my trips to furthur my testing with pressure/flow points on the vehicle exterior. I have used up to 6 gauges at once connected by plastic tubes taped to different spots on the car. I really need a passenger to record the readings at 60 mph, but I am able to do it if I read 1 or 2 at a time.
Have cut down on all driving quite a lot. I am making 1 trip in 1-1 1/2 weeks instead of 3-4 per week to my shop. An employee just bought a home near me and I send and receive deliveries by him almost daily. I do most of my work at my home shop.
Go 'GasMisers5'.
CO ZX2 is offline
Old 07-01-2007, 08:59 PM   #434
100 mpg tank
Go 'GasMisers5'.
Congratulations. This got to be the first 100 mpg tank for a spark ignition engine car. I know the diesel Smart made it there first.
I almost always ran with the knock sensors disconnected on my Ford Turbocoupes. The sensor seemed to pick up piston noise. At least I could never hear the knock it was responding to .
usedgeo
usedgeo is offline
Old 07-01-2007, 09:25 PM   #435
CO ZX2's Avatar
Thanks. I am proud of what Old Reliable has done, but I hesitate to consider this a real 100 mpg tank, it being comprised of a 3.24 gallon fill. Today was my deadline for a fill this cycle.
CO ZX2 is offline
Old 07-02-2007, 05:41 AM   #436
Unbelievable. That is truly amazing.
As far as recording readings, I was wondering if maybe you could put a digital camera on a tripod and snag all the readings at once. Just a thought from a lowly grasshopper.
Bill in Houston is offline
Old 07-02-2007, 07:15 AM   #437
CO ZX2's Avatar
Thanks, Bill. I will try a camera next test. I need to capture the small graduations. My gauges are quite large
(4 in.) so this may work OK. Kinda glad I didn't get the 2 1/2 inch gauges I wanted.
Tripod may be a slight problem. I don't have a bus like yours. But I will figure something out.
CO ZX2 is offline
Old 07-02-2007, 07:44 AM   #438
brucepick's Avatar
Standard tripod sockets are 1/4-20. I used to shoot professionally years ago. You should be able to cobble up something easily.
You don't want to drive the screw in hard against the stop at bottom of screw hole. There's camera guts behind there. You need a screw and a nut and probably a flat plate between nut and underside of camera. To tension the screw against the camera body bottom surface. You can substitute a wing nut + washer so you won't need a wrench to tighten/loosen.
Older European cameras were another size but that's vintage stuff. Just take the camera into a hardware store and ID the thread size.
brucepick is offline
Old 07-02-2007, 09:21 AM   #439
Semi-retired OPEC Buster
BeeUU's Avatar
fill for last cycle
36.2 mpg
Lost a bunch compared to last fill. A couple of autocrosses and more "normal" driving and big sticky tires has taken its toll.
B W
BeeUU is offline
Old 07-02-2007, 10:16 AM   #440
New tank
245.3 miles 5.65 gallons 43.41 mpg
repete86 is offline
Closed Thread
