Standings and Stats: Beginning May 21 - Page 46 - Fuelly Forums
Closed Thread
Old 07-03-2007, 07:17 AM   #451
brucepick's Avatar
Team Leftover Bananas
This morning's fill:
123.9 mi., 4.149 gal = 29.862 mpg
Ugh. I had to go shopping for a coffee pot which required about 5 stops till I found a decent one.
brucepick is offline
Old 07-12-2007, 03:38 PM   #452
Peakster's Avatar
First fill in nearly a full month: 280.9 miles travelled, 7.15 gallons used = 39.28 MPG(US)
Not exactly inspiring, but on the plus side, I've only spent $30 in fuel this month (and I should be good until August).
Peakster is offline
Old 07-13-2007, 04:32 AM   #453
Moderator
GasSavers_DaX's Avatar
Looks like it might be another 600+ mile tank for me... Currently at 470ish with about 1/8 tank left.
GasSavers_DaX is offline
Old 07-13-2007, 12:59 PM   #454
XFi
XFi's Avatar
Over 50mpg
Had two fills this week (Wed and Fri). 50.56 and 53.52. The only main difference between them was that I adjusted my timing again. I have been getting some pinging/detonation so I stepped up my octane this fill to see if that helps. I have been keeping all my highway speeds to a max of 55-60mph.
The 53mpg was a personal best for me in the Xtiva.
If 53mpg wasn't a bad fill or a fluke...I should hopefully reproduce that (or more ) next tank.
*EDIT* I guess I jumped the gun by saying the timing was the only difference. I have noticed my exhaust getting louder everyday....Well, It finally let go. The down pipe off the exhaust manifold (to cat) just fully seperated. REALLY LOUD NOW! I believe this reduction in exhaust back pressure may have been the mpg increase. It also recently has been having trouble holding a steady idle. This makes sense due to the lack of back pressure. I will not be driving till I put on a new pipe (I have read that running an open exhaust manifold may cause valve damage). Time for some free flowing exhaust???
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline
Old 07-14-2007, 04:19 PM   #455
ELF
ELF's Avatar
I am out, The sable is gone for good. After replacing the motor in my moms windstar, it worked for 2 weeks then the tranny blew
So were getting rid of the POS and shes now the proud owner of a 00 Sable!
So I am off the slow burn team It was fun while it lasted guys!
ELF is offline
Old 07-14-2007, 04:30 PM   #456
FE nut
diamondlarry's Avatar
ELF, sorry to hear that. I hope you are able to find a replacement vehicle(very FE friendly of course ) quickly and maybe you can rejoin later.
Edit: If there is anyone reading that would like to take ELF's spot, PM me and I'll pass it along to The Commish.
2007 Prius,
Team Slow Burn
diamondlarry is offline
Old 07-19-2007, 02:25 PM   #457
Exclamation Thread Moving
To keep things organized, the Cycle 2 thread will be closed to make way for a convenient place to post Cycle 3 updates. Feel free to quote anything from this thread.
Good job guys (and sorry to hear about the Sable, ELF )
Even though auto-downloads are used for calculations Feel free to post updates to keep the challenge exciting!
Later...
Commish
rh77 is offline
Closed Thread
